BB Stage VI heads #1202277
03/24/12 12:49 AM
03/24/12 12:49 AM
Eastern WA
P
ProStock1320 Offline OP
P
Eastern WA
I heard a rumor offset rockers were needed with the aluminum Stage VI cylinder heads for wedge engines. I looked into the old DC catalog and it states "uses stock valve train parts." But, I also have heard tell of some "special" Stage VI heads that required offset rockers. Can anyone shed any light on this?
Re: BB Stage VI heads [Re: ProStock1320] #1202278
03/24/12 01:12 AM
03/24/12 01:12 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Mine uses standard rockers, I use Hughes Engines CNC 1.5 on my 496...
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: BB Stage VI heads [Re: Wicked49670dart] #1202279
03/24/12 01:33 AM
03/24/12 01:33 AM
Eastern WA
P
P
Eastern WA
Thanks, that's what I thought too. But there is always the odd parts that get 'tweaked' (Hurst, Mr Norm, etc.) and one thing I have learned in this hobby - never say never when Mopars are concerned.
Re: BB Stage VI heads [Re: ProStock1320] #1202280
03/24/12 01:42 AM
03/24/12 01:42 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I've had a set for over 15 years, and they needed a bunch of fine tuning and various upgrades to get them right. You can post on the racers forum for tons of info.
Re: BB Stage VI heads [Re: buildanother] #1202281
03/24/12 01:52 AM
03/24/12 01:52 AM
Eastern WA
P
P
Eastern WA
Good idea. I'll let it soak here a bit and try the Race Forum next. Thanks.
Re: BB Stage VI heads [Re: ProStock1320] #1202282
03/24/12 08:04 AM
03/24/12 08:04 AM
tboomer Offline
tboomer  Offline
From the tech archive..Lots of reading!
http://www.moparts.org/Tech/Archive/bb/33.html
Re: BB Stage VI heads [Re: ProStock1320] #1202283
03/24/12 10:34 AM
03/24/12 10:34 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I just acquired a set, what appears to be the second version/casting, that were produced around the 1999-2002 timeframe. Yep, the catalog does say that they use the production valvetrain. I mocked up one head and the stamped steel rocker & non-adj. pushrod pieces fit perfectly to the lifters. Not that I'd use them. No interference at the cylinder head-to-pushrod passthru.
It is the "Max Wedge" versions that came later that need a special offset rocker. NOT all Stage VI'ers.
Re: BB Stage VI heads [Re: Dean_Kuzluzski] #1202284
03/24/12 11:15 AM
03/24/12 11:15 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Sorry thought I had a pic of my set-up. I'm using H/S rockers. Mone have been ported and seem to breath well. They do raise your headers up a tad so check around before you order. Other wise the header flange might rattle on your t-bars.
Coming soon!!!!
Re: BB Stage VI heads [Re: Mr.Yuck] #1202285
03/24/12 11:48 AM
03/24/12 11:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
here are mine, you notice some have been grined on.. helps w/ valve cover clearance.
Re: BB Stage VI heads [Re: Mr.Yuck] #1202286
03/25/12 02:45 AM
03/25/12 02:45 AM
Eastern WA
P
P
Eastern WA
More thanks all around.
Here's what's up; I have a new set of VIs that have been CNCed & hand blended, 11/32 guides, bigger valves. I have a buddy who is considering a set and has had a conversation with a fellow in the Georgia area who indicated some offset was needed in the rockers.
My friend asked me & all I could say was what I found in the DC parts catalog. My question is/was to get the straight scoop from those that know (where better than Moparts, right?) before I spend money on the valve train & my buddy knows whether he can use what he already has if he goes with the VIs.
Based on the responses & the archive thread (THANKS boomer!), I think we can confirm the stock stuff, as cited in the catalog, is correct.
Best wishes to all for a great 2012 season!
