Can you flip an A body (71) front spring hanger, 2 lowr #1202047
03/23/12 08:19 PM
03/23/12 08:19 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Can you flip the front spring hanger upside down on an A body to lower the car some? Its on a 71 Duster.
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: NV69B7RR] #1202048
03/23/12 08:42 PM
03/23/12 08:42 PM
AndyF Online content
AndyF  Online Content
Yes, but you have to hack on the holes in the chassis to make it work since the bolt pattern isn't square.
Mancini Racing has the correct hangers with a second eye bolt hole.
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: AndyF] #1202049
03/23/12 10:25 PM
03/23/12 10:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hack?
Dunno if I'd call it a hack. A bit of time with a file is all. Course, I don't have anything to sell in this discussion.
Don't be the exception.
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: Supercuda] #1202050
03/23/12 11:26 PM
03/23/12 11:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hack?
a couple minutes with a file, I've done it on dozens of cars, never an issue.... But if I was selling parts I'd offer that as a better option...
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: 1_WILD_RT] #1202051
03/24/12 01:23 AM
03/24/12 01:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
In a mild perfoming car, hogging out the holes probably won't hurt. I certainly wouldn't do it with a 4 speed or a 14 second or quicker ride. The mounting area in most cars is not that thick unless the reinforcing plates are there.
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: Kern Dog] #1202052
03/24/12 02:10 AM
03/24/12 02:10 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: Kern Dog] #1202053
03/24/12 10:30 AM
03/24/12 10:30 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Have you ever heard of anybody having a problem caused by doing this?
I haven't, not even the "friend of my buddies' cousin's sister's nephew" variety.
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: Supercuda] #1202054
03/24/12 10:56 AM
03/24/12 10:56 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
not a race car comment. but the factory, suggestion from the zone rep, repair for dog tracking volaries, rear spring mounts welded in the wrong place. was to install shims between the hanger and the body. i remember doing a few that i had to use longer bolts in the hangers because there were so many shims. i lost count on the number of cars i did that to and never had one come back. never heard of one breaking several had well over 100K miles after the repair.
perception is 90% of reality
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: Mr T2U] #1202055
03/24/12 11:49 AM
03/24/12 11:49 AM
BDW Online content
BDW  Online Content
Just out of curiousity, how big a "hog" we talking about?
1/4", 1/2", larger..............?
All 4 holes, or just 2?
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: BDW] #1202056
03/24/12 12:01 PM
03/24/12 12:01 PM
just 2
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: RapidRobert] #1202057
03/24/12 12:13 PM
03/24/12 12:13 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
In the pic above look at the space between the upper studs compaired with the space between the lower studs. Thats the hog.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: BDW] #1202058
03/24/12 02:14 PM
03/24/12 02:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Personally I move all four, but it's less than 1/8th of an inch... If your concerned about it you can make it stronger than it ever was by adding a spring hanger reinforcement... Which came stock on some HP models...
Re: Can you flip an A body (71) front spring hanger, 2 lowr [Re: 1_WILD_RT] #1202059
03/24/12 04:03 PM
03/24/12 04:03 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
you ever notice any wheelhop when this is done? I like my front segment to be flatter, but I put the extra holes in my minitub spring relocation and it hopped bad, like it was gaining and losing traction as the springs went up in the front slightly. Put it back in the normal hole and it went away. I just have a mild 273 and 5 speed.
