Today is D-Day for the new bullet! #1201791
03/23/12 05:53 AM
03/23/12 05:53 AM
Clinton Township, Michigan
Dartin Offline OP
Dartin  Offline OP
Looks like we will be going up on the dyno today with my new 540!!! Anyone care to take make any guesses as to what it will make? Before any of the nay-sayers start jumping in, I realize that dyno numbers should be taken with a grain of salt and that the real numbers come out at the track. Here is a brief run down of the combo:
World Mega Block- 4.500" bore
Callies 4.250" crank 2.2" rod
Callies CompStar H-Beam rods
Diamond custom pistons
Comp roller cam and lifters (duration @.050"= 274 int/280 ex 112 c/l 740" lift)
Trend pushrods- pushrod oiling
Indy -1 345CNC heads flow 370 @.700"
Jesel 1.7 rockers
Manley Nextek springs
Manley intake, Ferrea exhaust valves
Indy 440-2 intake
Holley 1150 Dominator
Hamburger oil pan
Milodon dual line swinging pick up
Compression is about 12.5:1
Thanks are owed to Shawn Meyer at St. Claire Engine in Richmond, Mi. for his engine building talent and patience with me and all of my stupid questions.
I would also like to thank HardcoreB for his help as well as Bob George for advise and parts.
I will try to post video and pictures with the results tonight or tomorrow.
Wish us luck!!!
Randy
Re: Today is D-Day for the new bullet! [Re: Dartin] #1201792
03/23/12 09:05 AM
03/23/12 09:05 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
depending on head flow and cam....835hp..
Re: Today is D-Day for the new bullet! [Re: Dartin] #1201793
03/23/12 09:34 AM
03/23/12 09:34 AM
NC
440Jim Offline
440Jim  Offline
NC
Comp roller cam and lifters (specs later)
Guess later...
What size headers were used on the dyno? (dia and length)
But that should make some good power.
What the moderate compression ratio gives up, the large CID should compensate, and with the right converter won't kill the drag strip performance. But I would have liked to see more CR.
Why did you pick that CR?
EDIT: After seeing the cam and 2" headers, it should make just over 800 hp. The heads might be worth a touch more.
Re: Today is D-Day for the new bullet! [Re: Dartin] #1201794
03/23/12 02:52 PM
03/23/12 02:52 PM
Make sure the headers fir the exhaust ports Mine didn't and the motor would start to miss above 5200 RPM, same heads and headers on two different short blocks miss with those headers My 526 C.I., 4.380 bore x 4.375 stroke, motor with similar compression made 845 HP at 7000 RPM missing on a DTS dyno at 4300 Ft above sea level Yours should make more
Re: Today is D-Day for the new bullet! [Re: Dartin] #1201795
03/23/12 09:06 PM
03/23/12 09:06 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
Just curious if you bushed the lifter bores, did you restrict oiling anywhere? Doing a similar build myself.
Re: Today is D-Day for the new bullet! [Re: Thor500] #1201796
03/23/12 09:30 PM
03/23/12 09:30 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I'm going to say around 840hp.
Good luck!
Re: Today is D-Day for the new bullet! [Re: Diablo] #1201797
03/23/12 09:42 PM
03/23/12 09:42 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
First of all Im glad to hear things are coming together for you Randy.Now as far as a guess I will say 825Hp.
Wish you the best.Jeff
Re: Today is D-Day for the new bullet! [Re: Thor500] #1201798
03/23/12 10:58 PM
03/23/12 10:58 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
775HP
Mopar Performance
Re: Today is D-Day for the new bullet! [Re: moparniac] #1201799
03/23/12 11:02 PM
03/23/12 11:02 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Looks good Randy. I put the crank and cam in mine tonight. Look forward to seeing you at the track.
Doug
Re: Today is D-Day for the new bullet! [Re: dvw] #1201800
03/24/12 12:23 AM
03/24/12 12:23 AM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
The last 540 Wedge that we built and dynoed made 813HP. That was with a similar combo except it was a NSS/Max Wedge class engine using the Indy crossram and dual Edelbrock carbs. I believe that your combo
should make 850+ because of the better intake and carb combo. My customer ran a 9.68 with that combo in 3400 pound B-body. After 3 seasons of racing we freshened that engine, bored to 4.530, did our hand valve job and changed nothing else in the engine. The result was a best run of 9.48. We are estimating that engine at 830HP now. Hope this gives you a good idea of what you should expect.
Jeff Day
Precision Automotive Machine
Canton, Ohio
Re: Today is D-Day for the new bullet! [Re: jdfpam] #1201801
03/24/12 12:38 AM
03/24/12 12:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy called me this afternoon to see if I had a
balancer... they had problems with his.... I did
have one but Sean found a ATI one over in the shop...
so they were running late
Re: Today is D-Day for the new bullet! [Re: MR_P_BODY] #1201802
03/24/12 06:01 AM
03/24/12 06:01 AM
Dartin Offline OP
Dartin  Offline OP
First off, I would like to thank everyone for their interest and well wishes! Holy smokes, I don't know where to start. It was one heck of a day.
We started making some initial pulls to get a base line only to find out that the only part I re-used from my old motor was bad. I had a Summit SFI balancer that only had about 50 passes or so on it and when Shawn checked the timing he found that the ring had slipped a whole bunch. Sean (HardcoreB) ran home and grabbed the one for his build (thanks a bunch) while we pulled mine.
I had bought a factory reconditioned 1150HP Dominator and we just couldn't get the fuel curve to come in after jet and air bleed changes. Sean to the rescue again! He had an older modified Dominator of unknown origin that we swapped .
Second pull with that carb and and our last drops of fuel netted us the best numbers of the day. 830 h.p. @6700 rpm and 775 ft. lbs. of torque @5500 rpm! This is right where Shawn said it would be. I will try to post some pics and video later today.
Randy
Re: Today is D-Day for the new bullet! [Re: Dartin] #1201803
03/24/12 07:16 AM
03/24/12 07:16 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
NICE,,,,,congrats
Re: Today is D-Day for the new bullet! [Re: Dartin] #1201804
03/24/12 10:03 AM
03/24/12 10:03 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Jesel 1.7 rockers
Indy 440-2 intake
Hamburger oil pan
Mopar Performance
Re: Today is D-Day for the new bullet! [Re: moparniac] #1201805
03/24/12 10:13 AM
03/24/12 10:13 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Nice job Shawn and Randy
Re: Today is D-Day for the new bullet! [Re: 340RICK] #1201806
03/24/12 10:31 AM
03/24/12 10:31 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Great job!!!
Re: Today is D-Day for the new bullet! [Re: Diablo] #1201807
03/24/12 10:32 AM
03/24/12 10:32 AM
tboomer Offline
tboomer  Offline
Pretty darned good!
Re: Today is D-Day for the new bullet! [Re: tboomer] #1201808
03/24/12 11:44 AM
03/24/12 11:44 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Pretty darned good!
ditto...
Re: Today is D-Day for the new bullet! [Re: Dartin] #1201809
03/24/12 11:45 AM
03/24/12 11:45 AM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
Oh Yah! That is a nice piece. You should have a lot of fun racing with that thing
Re: Today is D-Day for the new bullet! [Re: 66er] #1201810
03/24/12 11:54 AM
03/24/12 11:54 AM
s.e. michigan
top8x7b Offline
top8x7b  Offline
s.e. michigan
randy looks like that will move the dart right along ,now the fun begins sortinh the new combo out in the car .
