Disc brake vs drum brake master cylinder #1201721
03/23/12 01:03 AM
03/23/12 01:03 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Previous owner of my '69 Barracuda put disc brakes from a '73-up A body on the front but it appears to have the original drum brake master cylinder. I'm using the car for a race car and don't want to throw money at it if I don't have to. So, will the original master cylinder work or do I need a disc brake MC?
Re: Disc brake vs drum brake master cylinder [Re: VITC_GTX] #1201722
03/23/12 01:06 AM
03/23/12 01:06 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You DO want to stop, right?
The Disc M/C has a larger front reservior to adequately serve the larger volume of fluid that the calipers require.
Its only about $25 plus fluid for an AutoZone rebuilt one. Money well spent.
Re: Disc brake vs drum brake master cylinder [Re: Kern Dog] #1201723
03/23/12 01:24 AM
03/23/12 01:24 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Good thought. I was trying to avoid having to change the brake lines since I'm convinced the fittings will be different sizes.
Re: Disc brake vs drum brake master cylinder [Re: VITC_GTX] #1201724
03/23/12 02:48 AM
03/23/12 02:48 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Same size lines, same fittings on the ends too.
