408 Stroker with Power brakes? #1201702
03/23/12 12:57 AM
03/23/12 12:57 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Considering the 408 stroker for my project, but again looks like it is not power brake friendly. Anyone know for sure?
474 Intake / .474 Exhaust & 238 Intake / 238 Exhaust duration @ .050 - 110 degree lobe separation
Thanks.
Re: 408 Stroker with Power brakes? [Re: cudabitten] #1201703
03/23/12 08:33 AM
03/23/12 08:33 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
That shouldn't be a problem, but you're approaching the limit.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 408 Stroker with Power brakes? [Re: cudabitten] #1201704
03/23/12 08:45 AM
03/23/12 08:45 AM
NY usa
540challenger Offline
NY usa
Thanks.
Look like the cam in my blue printed crate 408. It is fine if it is the same engine i pull over 17 inchs of vac at idle.
On another note if it is the blue printe engine don't do it. I had to spend over 1400.00 bucks just to fix the pos. PM if you need more details
Re: 408 Stroker with Power brakes? [Re: 540challenger] #1201705
03/23/12 11:07 AM
03/23/12 11:07 AM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
What compression and intake? It's not only the cam that effects idle vacuum.
WIZE
In Car:
Re: 408 Stroker with Power brakes? [Re: Streetwize] #1201706
03/23/12 01:43 PM
03/23/12 01:43 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Good point. I was kind of blindly assuming a 10:1-ish motor.
Ignition advance makes a difference as well.
-Jim
Re: 408 Stroker with Power brakes? [Re: cudabitten] #1201707
03/23/12 04:00 PM
03/23/12 04:00 PM
California
Hotlumpy Offline
Hotlumpy  Offline
California
I have a 408 stroker in my 68 Barracuda with the following: 10:6:1 comp. Edelbrock heads, Air Gap, Holley 750, Hughes cam with 243 248 @ .50, .540-.550 lift. I am running power breaks and only pulling 9 inches of vacuum at idle, I kind of figured out a loophole by accident, I am running non-power disc break calipers off of a 71 or so Junkyard dart with my power system and it works quite well. Anyone else ever try this?
Re: 408 Stroker with Power brakes? [Re: Hotlumpy] #1201708
03/23/12 04:13 PM
03/23/12 04:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
71 four piston calipers are the same whether power or non power. It's the master clylinder bore that changes power vs. manual in those years' A-bodies (66-72)
Re: 408 Stroker with Power brakes? [Re: cudabitten] #1201709
03/23/12 04:14 PM
03/23/12 04:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks.
Sounds like a Comp XE274 hyd cam???
Re: 408 Stroker with Power brakes? [Re: autoxcuda] #1201710
03/23/12 04:59 PM
03/23/12 04:59 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
No. That's not the XE274H. I had that one in my 410... before it lost a lobe. But it is what I based my comment on. No hint of low vacuum in my combination. It's well into the teens. I run about 18 degrees of initial advance with a dual plan and 10:1 CR.
-Jim
Re: 408 Stroker with Power brakes? [Re: 471Magnum] #1201711
03/23/12 09:34 PM
03/23/12 09:34 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
I have a 70 Cuda with a 417 stroker and factory power brakes (disk front, rear drum). The motor is 9.5:1 compression with a MP 484 cam (241/241, .484/.484 lift). I pulls about 14-15" of vacuum and the brakes work fine.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: 408 Stroker with Power brakes? [Re: autoxcuda] #1201712
03/23/12 09:44 PM
03/23/12 09:44 PM
eastern, pa.
eastern, pa.
I'm not sure what cam it is. It is a BluePrint Engine, and I will probably not go with it after all. Looks like some board members here have had issues with this engine from BluePrint.
When I called them up to ask about the vacuum specification, they did not sound like they knew what they talking about. That why I figured I would ask you Guys.
Thank you for your responses.
I guess the price was too good to be true.
Thanks,
Chris.
Re: 408 Stroker with Power brakes? [Re: cudabitten] #1201713
03/23/12 11:07 PM
03/23/12 11:07 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
Forgot to mention, the specs on the cam you mentioned in your original post sound like it is the MP 474, the cam one size down from mine.
Re: 408 Stroker with Power brakes? [Re: loco340cuda] #1201714
03/24/12 12:34 AM
03/24/12 12:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Some will surprise you. My old 440 had the MP .557 cam with 10.0 comp and 906 heads and the power brakes worked fine. My new 493 has a solid flat tappet with 264 & 270 at .050 with .591 lift (.630 with my 1.6 rockers) with a 110 LSA and I have it in on a 106 ICL. The power brakes still work but if I stay on the pedal too long I can feel it starting to get harder. I am thinking about a vacum pump but 99% of the time on normal driving they feel normal. Its only when on the pedal long like a beltway ramp or if I let up and hit the pedal again right away. But I was surprised how good they work with this cam in my 493. Ron
