Re: 408 Stroker with Power brakes?
[Re: cudabitten]
#1201703
03/23/12 08:33 AM
03/23/12 08:33 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
That shouldn't be a problem, but you're approaching the limit.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: cudabitten]
#1201704
03/23/12 08:45 AM
03/23/12 08:45 AM
Posts: 2,826 NY usa
540challenger
NY usa
Considering the 408 stroker for my project, but again looks like it is not power brake friendly. Anyone know for sure? 474 Intake / .474 Exhaust & 238 Intake / 238 Exhaust duration @ .050 - 110 degree lobe separation
Thanks.
Look like the cam in my blue printed crate 408. It is fine if it is the same engine i pull over 17 inchs of vac at idle.
On another note if it is the blue printe engine don't do it. I had to spend over 1400.00 bucks just to fix the pos. PM if you need more details
[Re: Streetwize]
#1201706
03/23/12 01:43 PM
03/23/12 01:43 PM
471Magnum
Space Station #5
Good point. I was kind of blindly assuming a 10:1-ish motor.
Ignition advance makes a difference as well.
-Jim
[Re: Hotlumpy]
#1201708
03/23/12 04:13 PM
03/23/12 04:13 PM
Posts: 27,469 So Cal
autoxcuda
So Cal
I have a 408 stroker in my 68 Barracuda with the following: 10:6:1 comp. Edelbrock heads, Air Gap, Holley 750, Hughes cam with 243 248 @ .50, .540-.550 lift. I am running power breaks and only pulling 9 inches of vacuum at idle, I kind of figured out a loophole by accident, I am running non-power disc break calipers off of a 71 or so Junkyard dart with my power system and it works quite well. Anyone else ever try this?
71 four piston calipers are the same whether power or non power. It's the master clylinder bore that changes power vs. manual in those years' A-bodies (66-72)
[Re: cudabitten]
#1201709
03/23/12 04:14 PM
03/23/12 04:14 PM
autoxcuda
So Cal
Thanks.
Sounds like a Comp XE274 hyd cam???
[Re: 471Magnum]
#1201711
03/23/12 09:34 PM
03/23/12 09:34 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I have a 70 Cuda with a 417 stroker and factory power brakes (disk front, rear drum). The motor is 9.5:1 compression with a MP 484 cam (241/241, .484/.484 lift). I pulls about 14-15" of vacuum and the brakes work fine.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: cudabitten]
#1201713
03/23/12 11:07 PM
03/23/12 11:07 PM
loco340cuda
Tempe, AZ
Forgot to mention, the specs on the cam you mentioned in your original post sound like it is the MP 474, the cam one size down from mine.
[Re: loco340cuda]
#1201714
03/24/12 12:34 AM
03/24/12 12:34 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Some will surprise you. My old 440 had the MP .557 cam with 10.0 comp and 906 heads and the power brakes worked fine. My new 493 has a solid flat tappet with 264 & 270 at .050 with .591 lift (.630 with my 1.6 rockers) with a 110 LSA and I have it in on a 106 ICL. The power brakes still work but if I stay on the pedal too long I can feel it starting to get harder. I am thinking about a vacum pump but 99% of the time on normal driving they feel normal. Its only when on the pedal long like a beltway ramp or if I let up and hit the pedal again right away. But I was surprised how good they work with this cam in my 493. Ron
