Page 1 of 3 1 2 3
'71 Duster Front Suspension Woahs! #1201225
03/22/12 04:22 AM
03/22/12 04:22 AM
san diego
JonsGottaDusta Offline OP
san diego
Hello New Forum,
I'll first list off the front suspension modifications on my Duster and then the predicament we are currently facing.
11.75" Disc Brake conversion
Hotchkis strut rods
1" torsion bars
Boxed LCA's + K-frame
All poly bushings
Hellwig front bar
FR 16:1 manual steering box
Custom made heim-joint + sleeve instead of tierods
17" Mustang Bullit Wheels with 5.94"(?) backspacing
KYB Shocks
So the issue I'm having is that nothing fits right and after months of hassle I'm forced to throw some 15" steelies back on the car. Driving the car gave me horrendous bump steer -with how low it is- because the crappy KYBs were on the bottom end of their travel and rendered themselves useless. Fortunately, one of my good friends was an engineer at Bilstein and he got me a set of fully adjustable, custom valved shocks (off our measurements) and now I'm trying to come up with a way for everything to work properly.
The questions:
1.) Is there any variation of spacer or something that could make this wheel work with stock tie rods?
2.) The new shock ends are heim jointed ends, so there has to be something fabricated to mount them (upper mount). We were thinking about something similar to a first-gen mustang or falcon shock tower, since they are a little longer than stock. But I'm open to any input and and suggestions you may have. Fabrication isn't really an issue, it's just trying to find the proper setup for this.
Any comments or input you have is greatly appreciated, thanks.
Re: '71 Duster Front Suspension Woahs! [Re: JonsGottaDusta] #1201226
03/22/12 04:23 AM
03/22/12 04:23 AM
san diego
san diego
Another shot. One front, one rear.
Re: '71 Duster Front Suspension Woahs! [Re: JonsGottaDusta] #1201227
03/22/12 05:48 AM
03/22/12 05:48 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Those shocks are pretty, but you will have to make some oddball bracket to fit them to the car. This is sorta like buying a hat that is too small, then going to have your head shrunk. Why don't you just buy the correct shocks? if money is an issue, consider the time and materials you will spend trying to make the wrong shocks fit your car.
Andy F has posted a red 68 Valiant using the same wheels that you mention. To fit them, they spent HUGE bucks on brake and hub upgrades. It may be possible to do with stock 4.5 bolt pattern 11" discs for far less money. There was a thread on the topic of these wheels and the spacers needed to mount them. The thread is in THIS cornering forum. There are pros and cons over using wheel spacers, I'm sure that you are aware.
Re: '71 Duster Front Suspension Woahs! [Re: Kern Dog] #1201228
03/22/12 07:16 AM
03/22/12 07:16 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
Is it me or do the rod ends look like they are screwed on and lockbolted? Pop the ends off and see what you have. Those wheels will need a quality spacer. IIRC a B-body rear on an A-body make them work
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: '71 Duster Front Suspension Woahs! [Re: runinonmt] #1201229
03/22/12 08:47 AM
03/22/12 08:47 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Talk to Bob's Profab and use one of his front coil overmounts as the afcos he uses have the same mont as those shocks. All fab work allready done for you.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: '71 Duster Front Suspension Woahs! [Re: JonsGottaDusta] #1201230
03/22/12 09:20 AM
03/22/12 09:20 AM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
http://www.magnumforceracing.com/store/d...onversion%2EJPG
Magnum Force makes a coil over kit that uses a bracket you need. Might try and call them to buy just the bracket.
I'm Gumby dammit!
Re: '71 Duster Front Suspension Woahs! [Re: JonsGottaDusta] #1201231
03/22/12 09:21 AM
03/22/12 09:21 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
When you posted on FABO that you were running the newere wheels without a problem I was scratching my head because the 5.72 backspace wheels barely fit an a body. The only thing I can think of is try running a hubcentric wheel spacer and putting the stock tierods back on.
Hold it did you say all poly bushings including the lowers? I bet the lower bushings are moving around and causing your problems.
Re: '71 Duster Front Suspension Woahs! [Re: JonsGottaDusta] #1201232
03/22/12 10:40 AM
03/22/12 10:40 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
The questions:
1) You will need to use spacers or alter the track width of the brake hubs/rear axle to allow these wheels to work.
2) Lower mount should bolt on with a proper shouldered bolt. Upper mounts just need a saddle to mount the rod end, then weld or bolt the saddle to the stock mount are. You'll give up about an inch of travel to do this. Go here: http://www.speedwaymotors.com/
search afco universal shock mount. That's what you need.
Re: '71 Duster Front Suspension Woahs! [Re: moparpollack] #1201233
03/22/12 04:27 PM
03/22/12 04:27 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Assuming the Hotchkis struts are adjustable, poly lowers shouldn't be moving around.
Re: '71 Duster Front Suspension Woahs! [Re: JonsGottaDusta] #1201234
03/22/12 04:45 PM
03/22/12 04:45 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Needs to be spaced out away from tie rod. Is it hitting the upper ball joint, inner frame rails, and/or sway bar too?
What is it doing?: Feels loose, jumps from lane to lane, feel every crack in the road...?
I doubt it's actual bump steer (toe in/out during suspension travel). I just measured it in my A-body and it was pretty darn good.
I've run KYB's with the car very lowered. What was the distance between you LCA and frame?
Re: '71 Duster Front Suspension Woahs! [Re: autoxcuda] #1201235
03/22/12 06:17 PM
03/22/12 06:17 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The definition of bump steer may be confusing to some. I had a 2002 ram that was lowered 5 inches in the front and 7 in the rear. The lower control arms sat real close to the bumpstops. In a turn, the outside wheel would hit bumps and make the truck skip. This made the steering wheel turn in more. It made the truck feel twitchy. To some, this SOUNDS like bump steer. It was actually a matter of the suspension running out of travel and the tire probably coming OFF of the pavement momentarily!
Actual bump steer is best described by one of the more experienced and skilled members here.
Re: '71 Duster Front Suspension Woahs! [Re: Kern Dog] #1201236
03/22/12 08:40 PM
03/22/12 08:40 PM
Plano, TX
68440fish Offline
68440fish  Offline
Plano, TX
Not really - bump steer is just toe change during wheel travel. Ideally you do not want it to change. Toe out makes the car twitchy.
Michael Plano, TX 68 Barracuda Notch Pro Patina
Re: '71 Duster Front Suspension Woahs! [Re: JonsGottaDusta] #1201237
03/22/12 09:30 PM
03/22/12 09:30 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Jon, if you have not yet flipped the outer tie rod ends back to where they belong (under the ball joint knuckle), no amount of shock fussing will alleviate your bump steer. I thought I made that clear back when I tried to align it for you. You say that you have taken the Mustang wheels off, so I assume that was so you could put the tie rods back where they belong. Is that not true?
If you are still trying to make the Mustang wheels work on your car, I will simply repeat what Ron, myself and others have told you - get some wheels that fit your car properly. There are other wheels on the planet besides steelies and those Mustang wheels.
I apologize if I have misunderstood your post, and will step aside and let others weigh in if that is the case.
Down to just a blue car now.
Re: '71 Duster Front Suspension Woahs! [Re: 68HemiB] #1201238
03/22/12 11:26 PM
03/22/12 11:26 PM
NY NY
3
340duster340 Offline
NY NY
sounds like a basic set up you should not have any issues, unless the frame is bent or something is way out of wack.
if you have the stock tie rods and adjusters, try those back on.
once you get it driving/turning right with stock stuff you can trouble shoot the aftermarket stuff.
Re: '71 Duster Front Suspension Woahs! [Re: 68HemiB] #1201239
03/23/12 02:12 AM
03/23/12 02:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
!! Wait second. Hold the phone! I didn't see where he flipped the tie rods to the top side of the steering arm. Sounds like Steve has some inside insight on this.
Ok, from the bump steer measurements I took on my A-body car, that WILL give you a bump steer condition. That's changing the axis point up 1" to 1 1/2" up.
Usually with 17" rims you will have to run spacers to get an affective (net) backspacing of 5.7 to 5.5" But that is really dependent on the inside diameter of the particular rim you are using. Rim with the same tire size diameter will have different inside diameters near that ball joint.
Also the amount of caster you run can sometimes make the tie rod closer to the rim.
Re: '71 Duster Front Suspension Woahs! [Re: autoxcuda] #1201240
03/23/12 10:15 AM
03/23/12 10:15 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Agreed. Sounds like there is more to this situation.
Re: '71 Duster Front Suspension Woahs! [Re: TC@HP2] #1201241
03/23/12 03:24 PM
03/23/12 03:24 PM
san diego
san diego
Frankenduster: This has nothing to do with pretty shocks. The were specifically built for my car and custom valved by one of the head engineers at Bilstein, and they were a birthday gift. If I wanted $400 bolt in OEM-type shocks I could have bought them. This has to do with the performance aspect as this is going to be a ROAD RACE car, not a restoration. If that's the only advice you have I'd suggest you troll the restoration forum as this isn't supposed to be a place of standard Mopar close-mindedness.
Steve: Due to being at a new school and job the car hasn't been touched in a while. I've tried to find places with proper backspacing wheels that are the same design as current, but have been very unsuccessful in my endeavors. The tie-rod setup is being removed and it's all going back to stock. It just boils down to wasting more money on a temporary solution, which I'd like to avoid if possible. The flipped tie rods go back to something Ron told me could be done. I knew little-to-nothing about suspension at the time and didn't understand the aspects of geometry of changing those types of things, which is why it wound up that way.
runinonmt: those are adjusters on the shocks not screws.
Thanks to the others for the solid input. I measured the shocks and they are a hair over 1/2" wide, so I'm gonna have to come up with a different solution for the shocks. I talked to Eric and he said he measured these out longer than stock, so I definitely cannot put on something that is going to shorten it 1". Because I'll destroy the shocks if they bottom out before the car is on the bump stops.
Re: '71 Duster Front Suspension Woahs! [Re: JonsGottaDusta] #1201242
03/23/12 05:42 PM
03/23/12 05:42 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
Sounds like you know it all, I am in wonder as to why you are on here asking a question, when your knowledge put you in this situation of bad ideas being implemeted.
And your bilstein buddy didnt engineer anything for you, just grabbed some off the shelf shocks and said they were made for you. Nice try. Real smart engineer buddy, put some longer shocks on a lowered car
Re: '71 Duster Front Suspension Woahs! [Re: cageman] #1201243
03/23/12 10:01 PM
03/23/12 10:01 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Get some 18's and have a permanent fix dude....
Mopar to the bone!!!
Re: '71 Duster Front Suspension Woahs! [Re: 72Swinger] #1201244
03/23/12 11:26 PM
03/23/12 11:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I think that's the best answer yet.
Don't try to pinch a penny after all the work you've done. Get the proper wheels for the car. Let a Mustang guy run the Mustang wheels.
- Stu Harmon
Page 1 of 3 1 2 3
