Page 1 of 3 1 2 3
Gear Drive vs Roller Chain #1200993
03/21/12 08:03 PM
03/21/12 08:03 PM
Colorado Springs, Colorado
cool70cuda Offline OP
I’m looking to get some thoughts/comments on Gear Drives (vs) Roller Chains. I’m thinking of a Milodon Gear Drive for my BB. Any experiences bad or good, Pro’s and Con’s for either. Thanks, Bill
Re: Gear Drive vs Roller Chain [Re: cool70cuda] #1200994
03/21/12 08:26 PM
03/21/12 08:26 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Gear Drive vs Roller Chain [Re: 71yelladustr] #1200995
03/21/12 09:27 PM
03/21/12 09:27 PM
Run a chain--keep the extra $$ in your jeans--there has almost never been a race won because one had a gear drive---Chains get KILLED by stutter boxes at the dragstrip but otherwise--they are the way to go! Look for a quality chain--the import junk will strech like cooked pasta--the Japan chains are good as well as Aussie--for the $$ the Milodon ( who knows where they get it) is a good set--Todd at marsh Perf ( sponsor here ) has the Aussie units and they are good. A gear drive may have a place on a blown dragger but otherwise no big advantage. If not set up right they are a disadvantage. It is about $$$$$ Keep as much as you can except when buying a helmet and fire suit IMO. FWIW I am an engine builder but I race with junk my clients throw away--like streched chains stc--and I make it do pretty good!!
Re: Gear Drive vs Roller Chain [Re: cool70cuda] #1200996
03/21/12 10:18 PM
03/21/12 10:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a gear drive on 2 of my engine.... love them
and they dont get slop in them... the one has been
on the one for 9 years the other for 6 years...
wish I had another for the last engine I just built
Re: Gear Drive vs Roller Chain [Re: cool70cuda] #1200997
03/21/12 11:20 PM
03/21/12 11:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
The pros are they(gear drives) never vary do to stretching or wear One of the bad things listed about gear drives is they transmit vibration from the crankshaft to the cam that a chain or belt will absorb, not sure that is relevant The list goes on, I have used chains, belts and single idler gear drives but not dual idler I liked them all as far as performance Maybe a little advantage of the belt drives over the chains and maybe a little advantage to the gear drives over the chains, maybe not
Re: Gear Drive vs Roller Chain [Re: Cab_Burge] #1200998
03/21/12 11:50 PM
03/21/12 11:50 PM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
Gear drives transfer harmonics to the valve train the a chain or belt dont
Re: Gear Drive vs Roller Chain [Re: MCHBOB] #1200999
03/22/12 12:08 AM
03/22/12 12:08 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This is hearsay and rumours, prove it. Don't just show me someone else's post .. PROVE IT!
The folks over at Pete Jackson think differently.
Re: Gear Drive vs Roller Chain [Re: cool70cuda] #1201000
03/22/12 12:33 AM
03/22/12 12:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The KB gear drive I use on my SB I can adjust the
cam timing with the gears on ... granted I do have
to pull the timing cover unlike a belt drive ( I have
been thinking of making a cover so I would pull the
water pump and a cover) to make it some what easier
Re: Gear Drive vs Roller Chain [Re: cool70cuda] #1201001
03/22/12 12:43 AM
03/22/12 12:43 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've had a Pete Jackson dual idler gear drive in the hot rod since 2001. It's been used in a couple engines and has never given me any trouble. There are several thousand miles and countless high speeds runs on that thing. It still looked great with no measurable wear when I pulled the engine apart recently.
- Stu Harmon
Re: Gear Drive vs Roller Chain [Re: cool70cuda] #1201002
03/22/12 09:31 AM
03/22/12 09:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I love my Milodon gear drives.
Re: Gear Drive vs Roller Chain [Re: Dodgem] #1201003
03/22/12 09:43 AM
03/22/12 09:43 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Feets my kid runs the PJ in the 300.Been in probally 12 years at least.Never any problems and he has put a ton of miles on it.He instaled it for the whine.Yeah he was young when I put it in.Timing is rock solid.Rocky
Chrysler Firepower
Re: Gear Drive vs Roller Chain [Re: therocks] #1201004
03/22/12 11:19 AM
03/22/12 11:19 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
DANGER, DANGER will robinson gear drives will destroy your engine and possibly the entire planet with their powerful harmonic vibration rays.
i mean just because they use them on F1 engines that only turn 18,000 rpm doesn't mean we can use them on our pushrod dinosaurs
Re: Gear Drive vs Roller Chain [Re: jamesc] #1201005
03/22/12 11:24 AM
03/22/12 11:24 AM
jamesc Offline
jamesc  Offline
another design failure using gear drives...oops sorry my bad that's the cosworth DFV the most successful racing engine ever built
Re: Gear Drive vs Roller Chain [Re: jamesc] #1201006
03/22/12 12:24 PM
03/22/12 12:24 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
a engine with 4 cams, 32 valves and precision gears should no way be in the same topic with a single cam engine and general manufactured parts.
just sayin
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Gear Drive vs Roller Chain [Re: ] #1201007
03/22/12 12:35 PM
03/22/12 12:35 PM
Penna
70satelliteguy Offline
Penna
"Chains get KILLED by stutter boxes at the dragstrip "
I used my last timing chain for 5 years at the dragstrip with a 2 step with no perceptible chain stretch.Hundreds of passes! Checked it every season.
Mike
Re: Gear Drive vs Roller Chain [Re: bigtimeauto] #1201008
03/22/12 12:57 PM
03/22/12 12:57 PM
jamesc Offline
jamesc  Offline
why not? are we to believe that an engine turning twice as fast with three or four times as many gears in the train is not subject to the same (or greater) forces? they've been used in plenty of general manufactured two valve, single cam, pushrod engines as well. i've seen and used the milodon gear drives are you saying the gears aren't precision? i guess that's a matter of opinion from my perspective they are precision gears. gear drives have been being used in every type of engine from lawn mowers to race engines to aircraft to huge industrial engines for a hundred years. i call BS on the whole gear drive destructive harmonic deal. can anyone post verified information with regards to a gear drive causing problems (or failures) as opposed to millions of engines that have used them for a century without issue? generally speaking i would say the reason for chains and belts being used simply comes down to manufacturing cost, complexity and possibly weight. gear drives would normally be the most expensive, difficult to manufacture/implement and heaviest.
Re: Gear Drive vs Roller Chain [Re: jamesc] #1201009
03/22/12 01:33 PM
03/22/12 01:33 PM
The only bad thing I've heard about gear drives that I would trust was on a Pete Jackson dual idler gear drive on a BB Chevy, it broke a ear off of one of the Tru Arc snap ring retainers and that ear went into the oil pump locking it up and snapping the ol pump drive, spun bearings, broke a rod and put the car on its roof at 130 MPH, totaled a 1955 Thunderbird C/G car
Re: Gear Drive vs Roller Chain [Re: jamesc] #1201010
03/22/12 01:40 PM
03/22/12 01:40 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
it goes back to 4 cams and 32 valves versus single camshaft and valve layout.
if you ever were in on a spintron test is would all be crystal clear for you.
Re: Gear Drive vs Roller Chain [Re: bigtimeauto] #1201011
03/22/12 02:13 PM
03/22/12 02:13 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
With regards to Milodons gear drives, I just didn't like the noise. Setting up the cam timing can be a bit confusing too but once you've worked it out it's OK.
HTH's
Tig
Re: Gear Drive vs Roller Chain [Re: bigtimeauto] #1201012
03/22/12 02:33 PM
03/22/12 02:33 PM
jamesc Offline
jamesc  Offline
no offense but geeze i'm sorry i'm not so advanced as to be using a spintron i'm just a podunk backyard hack. i know the difference between a pushrod engine and a DOHC layout and have raced both. for crying out loud of course there's a huge difference between the two in action but that doesn't negate the fact that gear drives have been used in EVERYTHING including single cam layouts. so no it's not crystal clear why engineers would use an inferior drive system. explain to me why gear drives have been designed into and used successfully in millions of engines of just about every conceivable type for a hundred years if they're such a detriment? when these subjects come up people constantly say the gear drive is no good because of harmonics. a good chain setup will work fine for the vast majority of builds but don't think for one minute that chain isn't whipping around and having it's own impact when it comes to valve train action. chain, gear, belt all have their pros and cons. all have been used in millions of engines none of them is problematic or they would never have made it this far. i'm not trying to sell anything. i have a milodon gear drive on the sig car, a jesel on my other dragster, a chain on the 383 on the stand and i don't worry about any of them.
Page 1 of 3 1 2 3
