Re: Gear Drive vs Roller Chain
[Re: 71yelladustr]
#1200995
03/21/12 09:27 PM
03/21/12 09:27 PM
Run a chain--keep the extra $$ in your jeans--there has almost never been a race won because one had a gear drive---Chains get KILLED by stutter boxes at the dragstrip but otherwise--they are the way to go! Look for a quality chain--the import junk will strech like cooked pasta--the Japan chains are good as well as Aussie--for the $$ the Milodon ( who knows where they get it) is a good set--Todd at marsh Perf ( sponsor here ) has the Aussie units and they are good. A gear drive may have a place on a blown dragger but otherwise no big advantage. If not set up right they are a disadvantage. It is about $$$$$ Keep as much as you can except when buying a helmet and fire suit IMO. FWIW I am an engine builder but I race with junk my clients throw away--like streched chains stc--and I make it do pretty good!!
[Re: cool70cuda]
#1200996
03/21/12 10:18 PM
03/21/12 10:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a gear drive on 2 of my engine.... love them and they dont get slop in them... the one has been on the one for 9 years the other for 6 years... wish I had another for the last engine I just built
[Re: cool70cuda]
#1200997
03/21/12 11:20 PM
03/21/12 11:20 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
I’m looking to get some thoughts/comments on Gear Drives (vs) Roller Chains. I’m thinking of a Milodon Gear Drive for my BB. Any experiences bad or good, Pro’s and Con’s for either. Thanks, Bill
The pros are they(gear drives) never vary do to stretching or wear One of the bad things listed about gear drives is they transmit vibration from the crankshaft to the cam that a chain or belt will absorb, not sure that is relevant The list goes on, I have used chains, belts and single idler gear drives but not dual idler I liked them all as far as performance Maybe a little advantage of the belt drives over the chains and maybe a little advantage to the gear drives over the chains, maybe not
[Re: MCHBOB]
#1200999
03/22/12 12:08 AM
03/22/12 12:08 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Gear drives transfer harmonics to the valve train
This is hearsay and rumours, prove it. Don't just show me someone else's post .. PROVE IT!
The folks over at Pete Jackson think differently.
[Re: cool70cuda]
#1201000
03/22/12 12:33 AM
03/22/12 12:33 AM
MR_P_BODY
The KB gear drive I use on my SB I can adjust the cam timing with the gears on ... granted I do have to pull the timing cover unlike a belt drive ( I have been thinking of making a cover so I would pull the water pump and a cover) to make it some what easier
[Re: cool70cuda]
#1201001
03/22/12 12:43 AM
03/22/12 12:43 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've had a Pete Jackson dual idler gear drive in the hot rod since 2001. It's been used in a couple engines and has never given me any trouble. There are several thousand miles and countless high speeds runs on that thing. It still looked great with no measurable wear when I pulled the engine apart recently.
[Re: Dodgem]
#1201003
03/22/12 09:43 AM
03/22/12 09:43 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Feets my kid runs the PJ in the 300.Been in probally 12 years at least.Never any problems and he has put a ton of miles on it.He instaled it for the whine.Yeah he was young when I put it in.Timing is rock solid.Rocky
Chrysler Firepower
[Re: jamesc]
#1201006
03/22/12 12:24 PM
03/22/12 12:24 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
a engine with 4 cams, 32 valves and precision gears should no way be in the same topic with a single cam engine and general manufactured parts.
just sayin
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: jamesc]
#1201010
03/22/12 01:40 PM
03/22/12 01:40 PM
bigtimeauto
Trophy Winner
Trophy Winner
why not? are we to believe that an engine turning twice as fast with three or four times as many gears in the train is not subject to the same (or greater) forces? they've been used in plenty of general manufactured two valve, single cam, pushrod engines as well. i've seen and used the milodon gear drives are you saying the gears aren't precision? i guess that's a matter of opinion from my perspective they are precision gears. gear drives have been being used in every type of engine from lawn mowers to race engines to aircraft to huge industrial engines for a hundred years. i call BS on the whole gear drive destructive harmonic deal. can anyone post verified information with regards to a gear drive causing problems (or failures) as opposed to millions of engines that have used them for a century without issue? generally speaking i would say the reason for chains and belts being used simply comes down to manufacturing cost, complexity and possibly weight. gear drives would normally be the most expensive, difficult to manufacture/implement and heaviest.
it goes back to 4 cams and 32 valves versus single camshaft and valve layout.
if you ever were in on a spintron test is would all be crystal clear for you.
[Re: bigtimeauto]
#1201011
03/22/12 02:13 PM
03/22/12 02:13 PM
Posts: 2,923 A shed in England
Tig
A shed in England
With regards to Milodons gear drives, I just didn't like the noise. Setting up the cam timing can be a bit confusing too but once you've worked it out it's OK. HTH's Tig
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
