BB Distributor Phasing Modifications #1200597
03/21/12 12:35 AM
03/21/12 12:35 AM
Southern Illinois
Rocket65 Offline OP
Rocket65  Offline OP
Southern Illinois
I checked the phasing in my MP electronic ignition conversion distributor this evening by putting the motor on TDC and adjusting the reluctor wheel dead on the reluctor pick-up.
When I put my cap back on, the rotor appears to be half passed the #1 tower conductor (the rotor tip is half on and half off the brass tower conductor).
Also, I noticed that there is a lot of tolerance stack in the distributor. You can feel the distributor wiggle in the intermediate shaft slot and the rotor moves slightly on the shaft. Are there any mods I can do to fix this?
OOOORRR... Is there a better quality distributor that works with the Mopar ignition system?
Could this be the cause of my timing flickering ~1-2 degrees at idle? It cleans right up off idle and holds rock steady.
The vacuum advance is plugged off.
This thing is sloppy. I am not a fan of a sloppy distributor!
'65 Satellite - 512 6BBL; 10.8:1; 3600 Stall RMVB; 4.10:1 Dana w/Locker... Still tuning, going to the track soon!
Re: BB Distributor Phasing Modifications [Re: Rocket65] #1200598
03/21/12 04:42 AM
03/21/12 04:42 AM
Davis, California, USA
MrBelvedere2 Offline
Rick Ehrenberg sells a modified distributor reluctor to fix that problem. It comes with very comprehensive instructions on how to dial it in perfect. I put in on my car that has stock MP electronic ignition and it fixed the misfire I was chasing forever. And dead on on timing as well. I looked but he doesn't have one listed right now on ebay. But keep an eye out he has his own ebay store that he usually has them listed.
1965 Plymouth Belvedere II hardtop
Re: BB Distributor Phasing Modifications [Re: MrBelvedere2] #1200599
03/21/12 11:27 AM
03/21/12 11:27 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would like to find a few adjustable reluctors myself. Does anyone currently make them? I have not seen one for sale in a long time.
Re: BB Distributor Phasing Modifications [Re: Rocket65] #1200600
03/21/12 11:48 AM
03/21/12 11:48 AM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Simply replace it with a newer (firecore,petronics,FBO)dist that has no slop and a easier to set adv curve. I used one from FBO on my sixpack stroker and they set up the mec and vac adv to your combo (yes its a NEW dist NOT made by MP ) checked for out of phase on there dist machine. I just droped it in and set the total timing. It has a perfect curve and vac adv for my combo .
Re: BB Distributor Phasing Modifications [Re: THESHAKERPROJECT] #1200601
03/21/12 12:23 PM
03/21/12 12:23 PM
also reduce the dist shaft axial play to ~.005" by driving out the lower roll pin & sliding off the plastic collar and adding 1/2"ID flat washers above the collar then reinstall the roll pin. For rock steady timing need an added collar (Mcmaster-carr or others) on the lower dist shaft slotted tip to reduce it's rotational play in the inter shaft gear and a tight timing chain
Re: BB Distributor Phasing Modifications [Re: Rocket65] #1200602
03/21/12 12:53 PM
03/21/12 12:53 PM
AndyF Offline
AndyF  Offline
I used to make adjustable reluctors. I used them several times to solve "weird" ignition problems in customer cars. Typically what would happen is that the tolerance stackup would get the rotor part way between towers and then the spark would jump one way or another.
Re: BB Distributor Phasing Modifications [Re: AndyF] #1200603
03/21/12 01:08 PM
03/21/12 01:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I used to make adjustable reluctors...
I think I bought the last one that GregZ had at Carlisle some years back. Haven't used it, but am keeping it on hand for if/when I need to run an OEM-type distributor again.
Re: BB Distributor Phasing Modifications [Re: BradH] #1200604
03/21/12 10:34 PM
03/21/12 10:34 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
i phased my distributor by removing the indexing roll pin completely, then drilling & tapping a 10-32 hole between two "teeth" on the reluctor, then used a 1/8" long set screw(w/ loctite!) to lock the reluctor on the shaft. it took a few tweaks, but i managed to get it spot on by using an old cap with a hole drilled on top at the #1 tower to aim the timing light through.(use whiteout, or a white paint pen to draw a line down the centerline of the rotor so it shows up good with the timing light)
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: BB Distributor Phasing Modifications [Re: THESHAKERPROJECT] #1200605
03/22/12 12:33 AM
03/22/12 12:33 AM
Southern Illinois
Rocket65 Offline OP
Rocket65  Offline OP
Southern Illinois
Sorry for the semi-dumb question... but... what does FBO stand for? Firecore's distributor page is under construction right now.
I don't mind spending a few bucks on a part if it is precise...
Thank you guys for all of the good advice! I have bought from Rick on eBay before. I'll check that out, too.
Re: BB Distributor Phasing Modifications [Re: Rocket65] #1200606
03/22/12 11:03 AM
03/22/12 11:03 AM
Flite727's method would work & never thought of doing it that way.
Re: BB Distributor Phasing Modifications [Re: RapidRobert] #1200607
03/22/12 01:13 PM
03/22/12 01:13 PM
Flite_727 Offline
Flite_727  Offline
Gotta think outside the box every now & then!
the thing is, you have to be careful not to overtighten the set screw, or you could gouge the shaft and/or distort the reluctor.
Re: BB Distributor Phasing Modifications [Re: Rocket65] #1200608
03/22/12 08:20 PM
03/22/12 08:20 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
don told me" Fat Bald and Old"
Re: BB Distributor Phasing Modifications [Re: Flite_727] #1200609
03/22/12 09:55 PM
03/22/12 09:55 PM
Once I get in there to check it out a sleeve may be the way to go. Thanks again for thinking outside the box on this
