Windage tray spacing on a 360
#1200334
03/20/12 05:18 PM
03/20/12 05:18 PM
Posts: 847 Parsons (SouthEast) Kansas
funkyjbp
mopar addict
mopar addict
Everyone, I have slotted the holes on my 318-340 tray to fit on my 360 main bolts. Anyone know the correct spacing down? I have mocked it up using studs and washers but I had to use 3/8s of an inch to get it to clear the rods. I also bent it out a bit for clearance and now it's hitting on oilpan rail. Also, how much clearance is needed between tray and rod bolts? Just curious if anyone has done this before. Thanks, JP in the land Oz.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
79 Macho Short bed, 318
03 stratus coupe R/T
too many others not on the road!
Re: Windage tray spacing on a 360
[Re: GO_Fish]
#1200336
03/20/12 09:08 PM
03/20/12 09:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Back in the day, there was a specific windage tray for the 360. MP's windage tray is a universal fit unit, fits the 360 as well as the other LA's.
I have always had the windage tray want to ride on the oil pan rail, just wedge it out of the way, put the pan on without the timing chain cover and you can eyeball the fitment.
[Re: GO_Fish]
#1200337
03/21/12 12:02 PM
03/21/12 12:02 PM
funkyjbp
mopar addict
mopar addict
I have a 318-340 tray & am using on a stock stroke 360. The mopar performance trays come with slotted holes & washers to use under main bolts. I would like to get the washer thickness so I can space my tray accordingly. I got burned on ebay by buying a "360" tray as advertised. So I am trying to make it work. Thanks, JP in the land of Oz.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
