Re: 65 Coronet with poly 318 and cable shift TF
[Re: Fredmopar]
#1199981
03/20/12 12:32 AM
03/20/12 12:32 AM
Posts: 159 Woodward, PA
75DART440
Woodward, PA
I'm 99 percent certain an LA motor will bolt up. As for the poly, I think somebody makes a 4bbl intake. Cam would need to be custom made. As for the bottom end, it's still basic smallblock, so a stroker crank can be done.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!!
Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
[Re: 75DART440]
#1199982
03/20/12 06:24 AM
03/20/12 06:24 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
The LA bolts right up.The 66 Chargere my kid has we pulled the poly and put in a 70 LA.You will need to change exhaust also as poly is totally different.I believe one bolt dosent line up on the bell.Thats it.Rocky
Chrysler Firepower
