Installed height question... #1199888
03/19/12 10:10 PM
03/19/12 10:10 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
What is the easiest/simplest/least expensive method of going from 2.00 to 2.100 installed height?
We just got finished measuring the springs on my heads and for the replacement springs I'll need, I'm gonna have to bump up to the 2.100..
Currently there is a .060 shim on the intake and .030 shim on the exhaust..
Re: Installed height question... [Re: Jeepmon] #1199889
03/19/12 10:36 PM
03/19/12 10:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
Maybe +.050 keepers and + .050 retainers, if there available That or .100 longer valves with the keeper grooves moved up .100 Or get a different set of valve springs that will fit into your existing parts with the pressures you want The countless joys of building race motors
Re: Installed height question... [Re: Cab_Burge] #1199890
03/19/12 10:42 PM
03/19/12 10:42 PM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
Different retainers is your best option, unless you can find a spring that will work at 2.00. If you can sell your springs and get the other ones.
Re: Installed height question... [Re: Cab_Burge] #1199891
03/19/12 10:44 PM
03/19/12 10:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Or have the pockets cut .050 deeper IF you have the
material in the pocket and +.050 locks
Re: Installed height question... [Re: Jeepmon] #1199892
03/20/12 02:15 AM
03/20/12 02:15 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If you have standard height retainers, then finding a +0.100" retainer could be the easiest method, but if your using Ti retainers it could also be the most expensive. One issue with raising the retainer, is retainer to rocker arm clearance.
You could cut the valve spring seat deeper, but you need to make sure the seat is fairly thick first. Cutting the spring seats is fairly easy if the heads are disasembled, but it does take some setup time, and the heads will need to be cleaned up from all the aluminum shavings.
As mentioned, adding +0.050" valve locks is not too much extra cost, and the valve seat would not need to be cut as deep.
If you can find a spring that works at the 2.00" install height, that may be the simplest and easiest route?
Re: Installed height question... [Re: 451Mopar] #1199893
03/20/12 02:20 AM
03/20/12 02:20 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I really like getting the hands on experience with this motor build and I'm learning a lot as we go, but there are several areas that are completely foreign to me and installed valve spring heights is one of them..
Since I posted the question earlier, I believe I have found a set of springs that will work with these B1 heads.. and will not need any modifications to the installed height.. So thanks for the lesson.. you guys are great!!
