Replacing bench with power buckets in 71 4dr b-body
#1199361
03/19/12 01:11 AM
03/19/12 01:11 AM
Posts: 3,344 Central TX
roe
Central TX
Well, I saw another post that made me think about this swap. I want to take the rear bench and front buckets from a new charger (or 300 if it fits) and put it in my 71 satellite 4dr. From what I've seen the rears will drop right in, no issues.
My question is on the fronts. What exactly is necssary to replace the bench with buckets? Im guessing that if I just drill holes and bolt it in, the floorpan is not strong enough to properly secure the seats and will probably end up ripping out over time. Do I need to have some sort of bracing welded to the underside, or topside of the floors to spread up the force? Both? If extra bracing is necessary can they be bolted in or is welding in the only option?
I would also like to add in three point seatbelts at the same time, but thats another discussion.
Thanks in advance roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: Replacing bench with power buckets in 71 4dr b-body
[Re: roe]
#1199363
03/19/12 07:08 PM
03/19/12 07:08 PM
Posts: 152 MA
1968 Charger B5
MA
I used 71-74 bbody buckets in a 71 coronet i had....they fit the outer holes, i believe what i did was drill the inner holes, and i swapped the tracks and use washers as spacers to get the seats to sit flat....
1968 Dodge Charger R/T 1971 Plymouth Roadrunner 1998 Jeep Cherokee
