Bronze intermediate shaft gear, have you ever.... #1198435
03/17/12 04:43 PM
03/17/12 04:43 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
.....cut the step off the bottom and put a torrington washer in it's place to reduce wear?
It seems the bronze gear and the bronze bushing don't wear very well together? Wouldn't a machined/flat torrington take care of it?
I'm on my second one in many years, just inspected it and it's wearing mostly on the bottom just like the first (and like the others I have checked out, customer engines and so forth). It tends to score the steel shaft, because it's getting bronze particles thrown at it all the time.
I just pulled it, wasn't too surprised to see what it was doing...knocked the light scoring down with 600 grit and am going to put it back in. But have a longer term fix in mind....
I could have sworn I saw somebody selling them on ebay at one point years ago, already cut and with the washer, but maybe I've killed too many brain cells...
If not, thoughts? Good idea/dumb idea?
Rich H.
Esse Quam Videri
Re: Bronze intermediate shaft gear, have you ever.... [Re: ZIPPY] #1198436
03/17/12 04:57 PM
03/17/12 04:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never done it but it would be easy enough to do....
that just says your on the throttle tooo much... LOL
If I recall correctly it is pushed down when on your
on the pedal and lifts when you are decelling
Re: Bronze intermediate shaft gear, have you ever.... [Re: ZIPPY] #1198437
03/17/12 05:59 PM
03/17/12 05:59 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Funny, I thought the same ... all the used one's you see at swap meets are all worn off the bottom from two similar metals rubbing. I don't think it really needs a torrington in there and they're pretty thick. Just a good steel washer should do the trick. The torrington machined spacers(washers) are .030 thick so may not even need anything taken off the gear.
Anyhow that's what I plan to do.
Re: Bronze intermediate shaft gear, have you ever.... [Re: Stanton] #1198438
03/17/12 07:19 PM
03/17/12 07:19 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
no it's not a dumb idea, it's the way they should be made. i'm not sure but you may have to turn a recess in the gear to use a three piece bearing. OTOH a single hardened washer might work between the two bronze surfaces but i don't know if anyone has done this.
Leigh sent me this some time ago but i never ordered the parts. there had been a post about this very subject
"The Torrington number is NTA 815 and you have a choice of two different thicknesses thrust races. First one is .030 and the pn is TRA-815
Second one is .060 and pn TRB-815. You will need two races. I bought both sizes, but am only using the .030 thick ones"
here's the washer if you just wanted to use that washer
Re: Bronze intermediate shaft gear, have you ever.... [Re: ZIPPY] #1198439
03/17/12 07:57 PM
03/17/12 07:57 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
I did that years ago with great success,only i used just the flat washer and cut a oil feed groove in the bottom of the bronze gear. I didnt want to worry about little rollers in th engne?
Re: Bronze intermediate shaft gear, have you ever.... [Re: dodger mope] #1198440
03/17/12 10:55 PM
03/17/12 10:55 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Sounds like a good idea and maybe it'll help the oil stay cleaner
Re: Bronze intermediate shaft gear, have you ever.... [Re: DavidDean] #1198441
03/17/12 11:18 PM
03/17/12 11:18 PM
ky
68roadrunner Offline
ky
i thought one of the stocker guys was doing this, but dont remember who it was, sorry.
Re: Bronze intermediate shaft gear, have you ever.... [Re: 68roadrunner] #1198442
03/18/12 12:53 AM
03/18/12 12:53 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
larry sheppard came up with a bearing years ago. i beleive the article was in mopar muscle magazine. seeya.
Re: Bronze intermediate shaft gear, have you ever.... [Re: rickraw] #1198443
03/18/12 06:31 AM
03/18/12 06:31 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
what he said, but it is the larry shepard from akron, ohio (hemi's only ?) not the mopar enginner
Re: Bronze intermediate shaft gear, have you ever.... [Re: ZIPPY] #1198444
03/18/12 08:49 AM
03/18/12 08:49 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Exactly what happened to mine end of last summer. the crap showed up in my oberg. The washer sounds like a nice plan.
Mopar Performance
Re: Bronze intermediate shaft gear, have you ever.... [Re: ZIPPY] #1198445
03/18/12 10:50 AM
03/18/12 10:50 AM
NC
440Jim Offline
440Jim  Offline
NC
If it is a material issue, a simple hardened and ground "washer" is all that is needed. These are sometimes called "races" for torrington bearings. I don't see a need for putting tiny roller bearings in that application.
Re: Bronze intermediate shaft gear, have you ever.... [Re: 440Jim] #1198446
03/19/12 10:26 AM
03/19/12 10:26 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks for the input, it seemed like a good idea at the time, thought I should run it past you guys as a sanity check.
Been going through some maintenance on the gtx... I didn't hardly touch it last year, was concentrating on the shop build but now I can get back to the car projects
Rich H.
Esse Quam Videri
Re: Bronze intermediate shaft gear, have you ever.... [Re: ZIPPY] #1198447
03/19/12 01:58 PM
03/19/12 01:58 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
The KB kit has bearings.
I would like to use the washer myself.
Edit: I see that KB is putting the bearing on top of instead of under the bronze gear.
Sorry.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Bronze intermediate shaft gear, have you ever.... [Re: ZIPPY] #1198448
03/19/12 04:48 PM
03/19/12 04:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd like to be proactive re: eliminating this as a potential wear point when running my first roller on the street. Is the solid washer option thin enough to not require machining the bottom of the gear?
Re: Bronze intermediate shaft gear, have you ever.... [Re: BradH] #1198449
03/19/12 05:38 PM
03/19/12 05:38 PM
Mt. Eden Ky.
Mt. Eden Ky.
I'd like to know that too!
1996 Ram 1500 Sport
1968 road runner
Re: Bronze intermediate shaft gear, have you ever.... [Re: Hemi Allstate] #1198450
03/19/12 05:51 PM
03/19/12 05:51 PM
BradH Offline
BradH  Offline
The KB deal looks like what Dan Dvorak was selling, too. Compared to the simplicity of a $2 shaft collar, that thing is an effing Rube Goldberg contraption.
I spent the $$$ w/ Dvorak to have him do the install (he said it required some special fitting for proper length, IIRC) and it caused my distributor to wobble back and forth so badly when we fired the engine up on Porter Racing's dyno that we pulled it off after about 60 seconds of run time. I stuck it on my parts shelf and it's been sitting there for about nine years.
Re: Bronze intermediate shaft gear, have you ever.... [Re: BradH] #1198451
03/19/12 05:58 PM
03/19/12 05:58 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I'm assuming the gear will need to be machined, but that'd be great if it did not
Re: Bronze intermediate shaft gear, have you ever.... [Re: MR_P_BODY] #1198452
03/19/12 06:08 PM
03/19/12 06:08 PM
organ
maximum entropy Offline
organ
pushed down all tine engine run. all tine.
Re: Bronze intermediate shaft gear, have you ever.... [Re: maximum entropy] #1198453
03/19/12 06:21 PM
03/19/12 06:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Those washers are .030 thick. The gear will no doubt still mesh well with the cam, the question is whether or not there is .030 between the distributor shaft and the oil pump shaft. Easy enough to figure out ... take the o-ring off the dist. and see if you can bottom the dist. out on the motor. If so then you should be good to go.
