I bet I'm the 1st to ever do this!
#1198282
03/17/12 09:22 AM
03/17/12 09:22 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Welded the 16 extra lugs on to my Resto block to help hold down the Indy 360-2 heads. Used the head as a template using a drill sleeve in the extra head bolt holes to line them up perfectly...got 3/8 ARP studs going in them....used stainless mig wire and Argon/helium to keep from cracking.....hope it works...and helps. Don't try this with roller lifters.....I am using Smith machine composite solid flat-tappets and I ground out just enough material for them to sneak by.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
Re: I bet I'm the 1st to ever do this!
[Re: rickraw]
#1198286
03/17/12 11:05 AM
03/17/12 11:05 AM
Posts: 2,111 Byron, NY
W.I.N. Racing
Byron, NY
Something similar used to be done on "B" blocks so Hemi Heads could be used on them...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Stanton]
#1198288
03/17/12 11:25 AM
03/17/12 11:25 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
its something i would try. good luck
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Stanton]
#1198289
03/17/12 11:26 AM
03/17/12 11:26 AM
A57_RT
Parts Problem
Parts Problem
I bet I'm the 1st to ever do this! No, ive seen many hacked up blocks ....id not post that kind of work untill I seen if it worked or not and then....sorta like the fat chick in high school, alot of fun until your friends see ya on it.
[Re: A57_RT ]
#1198290
03/17/12 12:38 PM
03/17/12 12:38 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
At least your trying, but if it does work, you will only find the next weak link.
[Re: Dodgeguy101]
#1198291
03/17/12 12:48 PM
03/17/12 12:48 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I hope they don't break off and go through the engine. Hope it works out for you.
[Re: A57_RT ]
#1198293
03/17/12 01:50 PM
03/17/12 01:50 PM
instigator
north cakalaky
The lugs are welded on the sides and on the bottom...not across the top, which is why the parting line can be seen...I feel confident on the welds....I don't mind being different and going outside the box. I'll know when the studs are tightened down if all holds well. Half of the thread is in the meat of the block where the original lugs were milled off due to tooling of the 59 degree lifter bore..This is a R3 block with 4 bolt mains, heavier walls, bulkheads,deck, and filled pan rails, Manley pro-series rods , callies crank and custom Ross turbo pistons and pins, so there ain't much left in the way of the next weakest link!
Waiting on 18 bolt head gaskets from SCE (coppers)
[Re: instigator]
#1198295
03/17/12 02:33 PM
03/17/12 02:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have welded on blocks many times but all I ever used was nickle rod.... hope it works out for you... easy way to test it is... hit it with a hammer... hit the lug you welded on
[Re: reknapp52]
#1198299
03/18/12 12:26 AM
03/18/12 12:26 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I saw bolt on bosses for a big Ford and I liked the idea of it......A-460 heads on a stock block for po' folks like myself. I never got that far , but I had some crazy combos back then because I would buy stuff , then figure out how to use it. This works on paper..........let us know how it holds up on steel.
[Re: reknapp52]
#1198301
03/18/12 02:02 AM
03/18/12 02:02 AM
Posts: 25 California
Mad Dart
California
I think I still have that magazine article covering Charlie Malyuke's modifications--if I remember correctly, he used a silicon-bronze weld process.
I am sure it will hold since them extra Studs/Nuts are only going to be torqued to 45lbs. You only need enough so you don't pop a lung!!
