Re: 440 Source Water Pump and Housing
[Re: Stanton]
#1197952
03/16/12 02:00 PM
03/16/12 02:00 PM
Posts: 15,548 Norwich CT USA
moparts
Norwich CT USA
If they are still using the Cat water pump ??
It is a High Volume but only at higher RPM, not at idle where I needed it on my Challenger
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: Stanton]
#1197953
03/16/12 02:37 PM
03/16/12 02:37 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
There has been some moaning about the size of one of the passages on the "drivers side inlet" castings. I just hogged that passage out on the one I have as there's plenty of material in that area - it took all of ten minutes to do. Otherwise the casting is nice and fits fine. For the price you really can't beat it.
Did the thermostat housing bolt spacing get corrected ?
Otherwise the OP really has no alternative choice if he wants something other than the stock iron housing .
[Re: camd]
#1197955
03/16/12 05:00 PM
03/16/12 05:00 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Cheap China junk... Internal passages too small, will make an engine run 20-30 degrees hotter... Also the casting height is different from the OE Mopar aluminum one, forces one to use different spacers to get the proper fan belt/pulley alignment. May work OK for a casual cruiser but dump it if one has built the motor and/or lives in a hot climate. Just my $0.02...
[Re: GTXKen]
#1197957
03/16/12 08:58 PM
03/16/12 08:58 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Mine lined up perfect and cools my stroker motor just fine, all summer long.
Awesome... Glad it worked fine for you.. How hot does it get in the summertime in Indiana? We ran 1 for about a month on our 520 inch stroker, the temperature ran well about 210 degrees. Pulled it off, installed the Mopar OE water housing and temperature dropped 25 degrees..
We sold it for $25 @ last year's Spring Fling
Just my $0.02..
[Re: Sinitro]
#1197958
03/16/12 09:22 PM
03/16/12 09:22 PM
Posts: 5,899 Athens, Greece
Pyper70
Athens, Greece
Had the same setup...I sold it last year brand spanking new for $100 because I didn't want to be a statistic....Do so at your own risk. I went balls out and got the real one from Mancini with the matching HV water pump
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Dougsmopars]
#1197967
03/17/12 04:18 PM
03/17/12 04:18 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Had a 440source pump and housing on my 511" stroker street engine and it always ran cool with lots of street miles on it. Including long highway cruises where insufficient water movement usually presents itself.
2 kids and a dog
