Re: 318 versus 440 flywheel
[Re: magnum440d100]
#1197730
03/15/12 10:53 PM
03/15/12 10:53 PM
Posts: 4,285 Ohio
64dodge572
Ohio
318/440 crank flange is the same. Most 440's are neutral balance. 70-2 HP & 6pk engines had a special balance with a steel crank. Starting late in 72 most 440's got the cast crank which is a special external balance with the exception being some of the truck and 4-speed engines.
Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#1197731
03/15/12 11:09 PM
03/15/12 11:09 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
Dan
It's a 1979 440 out of a motor home. Would it be internally or externally balanced?? How do I tell??
[Re: magnum440d100]
#1197732
03/16/12 12:12 AM
03/16/12 12:12 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
It will have a cast crank and externally balanced. The harmonic balancer should read on the outer ring as follows; "440 cast crank only" It will vibrate with the 318 flywheel unless it is balanced for a 440 cast crank.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 440beep]
#1197735
03/16/12 10:04 AM
03/16/12 10:04 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Yes I know that. They have a "special balance" flywheel and balancer with the steel crank. I had a 72 440 with cast crank. It was a very late built engine.
Dan
[Re: 64dodge572]
#1197736
03/16/12 03:15 PM
03/16/12 03:15 PM
magnum440d100
woodcrest, CA
Dan
Dan. I noticed in your sig, Brewers performance. I'm on that site in another tab looking at the bolt on weights. Are those weights just for the flywheels you sell, or can they be used on a stock flywheel??
Looks like if I want to do a swap of either the 360 or 440 I need a new flywheel
Ugh. No one said it was easy, but now I need to decide what engine to swap
[Re: Kern Dog]
#1197740
03/16/12 04:54 PM
03/16/12 04:54 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All cast crank big blocks use the same external balance.
The register installed bushing/bearing is fine but the pilot shaft still needs a hole in the crank to clear the tip of the shaft. (or cut the tip of the shaft off)
[Re: pishta]
#1197742
03/17/12 12:37 AM
03/17/12 12:37 AM
magnum440d100
woodcrest, CA
I got a 143 tooth large flywheel from a truck. Im in So. Cal, Santa Ana area. Looks ready to run, smooth no rust, no glaze, pinhole to a balance hole but not affecting service. Its 14.5 in diameter and 11" clutch surface. probably 30 lbs specs to a big block forged app. $40 plus shipping if you want it. Ill post in sale items too.
Pm sent
