Page 3 of 3 1 2 3
Re: 400 BB Mopar dyno test part 2 [Re: tboomer] #1197357
03/17/12 03:01 PM
03/17/12 03:01 PM
USA
hudsonhornet7x Offline
USA
Thanks for the information about this combo
I have two questions:
1. I need a reliable set of rockers for my victor's and I need to know what brand will hold up to heavy street use ( 3-5,000 miles per summer)
2. I have a 431 with these heads being built. I would like to cnc the heads to make them flow as well as possible. Car is a 68 charger, 10.7 compression, 4 speed and 4:10 gears. What cam do I need?
Re: 400 BB Mopar dyno test part 2 [Re: hudsonhornet7x] #1197358
03/17/12 05:25 PM
03/17/12 05:25 PM
SoCal
Brian Hafliger Offline OP
SoCal
Hand porting is as good or better...Hughes rockers will fit the bill...what style of cam?
Brian Hafliger
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197359
03/17/12 05:35 PM
03/17/12 05:35 PM
USA
USA
I currently have a hydraulic flat tappet, but I am open to suggestions as to what type of cam and grind would make a good combination. I want to make the correct choice, and if I need to get rid of what I have previously bought, that is okay.
My cam right now is a comp xe275hl.
Re: 400 BB Mopar dyno test part 2 [Re: hudsonhornet7x] #1197360
03/17/12 05:51 PM
03/17/12 05:51 PM
SoCal
SoCal
I would go to a solid FT cam, maybe?
Brian Hafliger
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197361
03/17/12 05:56 PM
03/17/12 05:56 PM
USA
USA
I have been thinking along those same lines, but i have no idea where to start. Is a f/t very streetable? Also, What specs do I need to know to make an informed cam choice?
Re: 400 BB Mopar dyno test part 2 [Re: hudsonhornet7x] #1197362
03/17/12 06:09 PM
03/17/12 06:09 PM
SoCal
SoCal
You'll need to work with an engine builder to get the right cam. There's never too much info!
Brian Hafliger
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197363
03/17/12 09:36 PM
03/17/12 09:36 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I have a question, Will this fit under a stock 68 Charger hood??? Your pictures don't look like it is a very tall setup with the victor heads and RPM intake
I have a 4 spd 4.10 geared 10.4/1 470" low deck in a 68 Charger. I want to upgrade my heads. I am running MP 383/440 aluminum heads/.590 cam I have TTI headers for raised port heads already. Pistons are at 0 deck and chambers are 83cc if I remember correctly.
Re: 400 BB Mopar dyno test part 2 [Re: Joshs68] #1197364
03/17/12 10:00 PM
03/17/12 10:00 PM
SoCal
SoCal
Problem is even with porting I don't think the chambers can get anywhere near that so your compression will go up quite a bit.
Brian Hafliger
Re: 400 BB Mopar dyno test part 2 [Re: hudsonhornet7x] #1197365
03/17/12 11:07 PM
03/17/12 11:07 PM
IN
ahy Offline
ahy  Offline
IN
A FT cam is very much streetable. Lash will need checked once in a while. With good valvetrain parts, a check every 5,000 miles should be more than enough. Even then, it will probably need little to no adjustment. The solid FT will give a little wider power band and better top end perfomrance vs a hydraulic. I think setting lash is a lot more straight forward than setting pre-load on a high performance hydraulic so in a way, mechanical is easier.
Choice depends on your use of the car, engine displacement and mods, drivetrain (transmission/convertor, rear gear), power brake plans and your personal preference. Comp and Hughes have good shelf grinds.
For reference, I'm running a fast rate solid FT in a 496. As recommended by Muscle Motors, it specs out at 243 degree @ .050" intake duration with a 108 degree lobe seperation. Rockers are Comp cast steel "pro magnum" with 3/8" pushrods. It has been a very robust and reliable setup. The engine starts to wake up around 2000 RPM and really sings from roughly 3000 RPM. Peak HP is around 5600 (guess) and it pulls well to and beyond 6k.
Re: 400 BB Mopar dyno test part 2 [Re: ahy] #1197366
03/17/12 11:21 PM
03/17/12 11:21 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Yes, but pre-load is one and done. But I prefer solid ft.
Thank You Brian for sharing all of the information. There has been very little information based on experience about the victors.
I really hope the market opens up for the victors before edelbrock cans them.
Re: 400 BB Mopar dyno test part 2 [Re: viperblue72] #1197367
03/18/12 01:27 AM
03/18/12 01:27 AM
SoCal
SoCal
It's fun sharing info!!
I'll be building a 440 with these same heads in a month, but with a 275HL cam, 1.5 rockers, 9.8:1, M1 intake, 950HP carb and 1 3/4 header. I'll try the 1 7/8 header at the same time and post those results when I have them.
Brian Hafliger
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197368
03/18/12 03:16 AM
03/18/12 03:16 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Thanks for sharing, I always wanted to see some testing on a mild cam with a tight lobe separation.
Edit: oops nevermind just reread the first post and saw that you did a cam swap. No wonder the tq and hp were that high on the rpms lol.
Re: 400 BB Mopar dyno test part 2 [Re: moparmanjames] #1197369
03/18/12 06:27 PM
03/18/12 06:27 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
how much clearancing did you have to do for the 1.7'S?
Re: 400 BB Mopar dyno test part 2 [Re: tjmarcus1] #1197370
03/18/12 08:36 PM
03/18/12 08:36 PM
SoCal
SoCal
Alot!
Brian Hafliger
Page 3 of 3 1 2 3
