Page 2 of 3 1 2 3
Re: 400 BB Mopar dyno test part 2 [Re: gregsdart] #1197337
03/15/12 08:49 AM
03/15/12 08:49 AM
tboomer Online work
tboomer  Online Work
Great thread,Brian! I am also curious on the cc's out of the box. I hope my Victors are done soon!
Re: 400 BB Mopar dyno test part 2 [Re: tboomer] #1197338
03/15/12 10:09 AM
03/15/12 10:09 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Keep up the good work Brian
Rich H.
Esse Quam Videri
Re: 400 BB Mopar dyno test part 2 [Re: ZIPPY] #1197339
03/15/12 11:08 AM
03/15/12 11:08 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good thread Brian.
Re: 400 BB Mopar dyno test part 2 [Re: gregsdart] #1197340
03/15/12 11:19 AM
03/15/12 11:19 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Thanks for the post, Brian, love to read this stuff. Any chance you might try stealth heads on this combo?
A Stealth head dyno test would be great.
Nautilus Racing-
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197341
03/15/12 11:41 AM
03/15/12 11:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd not heard that Edelbrock was revising the Victor heads. Can you answer any of these questions?
Got any "old" vs. "new" flow tests for OOB standard-port Victors?
What size are the new chambers?
Any other changes to the new Victors besides chamber design and bowl dimensions?
Thanks,
Brad
Re: 400 BB Mopar dyno test part 2 [Re: BradH] #1197342
03/15/12 12:28 PM
03/15/12 12:28 PM
SoCal
Brian Hafliger Offline OP
SoCal
Thanks guys!
They are 72cc, but after valve job/chamber cut they ended up at 74.5cc.
I milled them down to 70cc to make 10.6:1.
Yes I was a bit disappointed in the power...we were planning on having 550'ish HP and after talking with Edelbrock they are not changing the head anymore so this is how they'll be. They told us the head is now geared more for the PORTER or ENGINE BUILDER...kinda sucks because the old port was really a bolt it on and make some power deal and now, just like every other Mopar head out there it needs TLC.
But....after some port work I'd say it's going to flat out work. I'd bet with porting we'd see that missing 40+HP.
No other changes seem to be in place from what I could tell.
Still for 2500.00 more than the mild 427HP version it made decent power. Would have been nice to hit 550's but porting put it over budget.
Brian Hafliger
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197343
03/15/12 01:14 PM
03/15/12 01:14 PM
BradH Offline
BradH  Offline
Now you have me fighting the urge to go buy a(nother) set of the "original" Victors from a guy near where one of my cousin lives that's being sold for a few hundred $$$ less than new. /
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197344
03/15/12 01:44 PM
03/15/12 01:44 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Thanks guys!
Have you ported a set of the old victors? If so, what number did you get out of them?
Good thing this wasn't a 4.15 stroke build up, otherwise I would have to sell a kidney to buy the engine from you when you were done...
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197345
03/15/12 11:21 PM
03/15/12 11:21 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thanks Brian.
What was the average and max power difference between the intakes?
Re: 400 BB Mopar dyno test part 2 [Re: BSB67] #1197346
03/15/12 11:57 PM
03/15/12 11:57 PM
SoCal
SoCal
Thanks Brian.
I'll post the graphs tomorrow nite. AVG HP and TQ was only 1 between the 2 intakes! It's a direct trade...low rpm power vs. high rpm power. If you call 5000-6500rpm high...LOL!
Brian Hafliger
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197347
03/16/12 10:40 AM
03/16/12 10:40 AM
USA
hudsonhornet7x Offline
USA
I just picked up a set of standard port victors ( new in box) on ebay for $ 900
How do I tell if the heads are the newer style or the original?
I am excited to use these heads and they will be going on a 431 motor.
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197348
03/16/12 10:55 AM
03/16/12 10:55 AM
NC
440Jim Offline
440Jim  Offline
NC
My first look at the new build dyno sheet, showed a fairly high torque peak (5100). So I looked at the previous build and it was much lower (4200). That much higher torque peak surprised me. The entire rpm range was moved up considerably, but as you mentioned the peak RPM wasn't too high.
Re: 400 BB Mopar dyno test part 2 [Re: hudsonhornet7x] #1197349
03/16/12 01:33 PM
03/16/12 01:33 PM
BradH Offline
BradH  Offline
If the chambers don't look like the pics that Brian posted above, they're the original style. It'll be pretty obvious if they're the older version.
Re: 400 BB Mopar dyno test part 2 [Re: BradH] #1197350
03/16/12 02:02 PM
03/16/12 02:02 PM
USA
USA
Thanks. By my pictures it looks like I have the older style. Is the older style preferrable to the new?
Re: 400 BB Mopar dyno test part 2 [Re: hudsonhornet7x] #1197351
03/16/12 02:23 PM
03/16/12 02:23 PM
SoCal
SoCal
OOTB the newer head will be down on flow and power, but has a better chamber.
I would not run the new head without a good valve job and chamber cut. That's what we did and it makes the head MUCH better.
Bowl porting is usually around 200-400 dollars depending on who does it, but I know after porting these heads will be well over 300cfm at .500 lift. Ours went 286cfm at .500 AFTER valve job and chamber cut.
But.......remember the chamber of the newer head is better (after chamber cut and some porting)and would really lend itself to a pump gas engine needing a large quench area.
From what I see, if you compared the older head to the newer head FULLY PORTED the newer head will make more power. But OOTB...no way!
Brian Hafliger
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197352
03/17/12 12:12 AM
03/17/12 12:12 AM
SoCal
SoCal
RPM intake graph:
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197353
03/17/12 12:13 AM
03/17/12 12:13 AM
SoCal
SoCal
RPM intake
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197354
03/17/12 12:14 AM
03/17/12 12:14 AM
SoCal
SoCal
RPM vs. Victor intake:
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197355
03/17/12 04:05 AM
03/17/12 04:05 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Interesting Brian, that this motor made about the same peak numbers as Mrs Gbob's 426 with the 950 on it.
Completely different combos, but similar peak outputs (although at different rpm levels).
426 results
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197356
03/17/12 12:50 PM
03/17/12 12:50 PM
tboomer Online work
tboomer  Online Work
I like that graph...When I get my Victors back,I will post the numbers,Brian. I am pretty sure they are the new style.
Page 2 of 3 1 2 3
