88 ramcharger not go into 4wd #1197219
03/14/12 10:37 PM
03/14/12 10:37 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Iv tried putting it into 4wd park netural going down the road under deaccelulration nothen looked under didnt see nothen bent or what is a commen problem that could cause this???? 88 318 tbi if matters
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 88 ramcharger not go into 4wd [Re: toplescuda] #1197220
03/15/12 02:00 AM
03/15/12 02:00 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Vacuum hose, switch or servo problem. Vacuum operates the servo that is mounted on top of drivers side axle tube. Somebody apparently makes a manual cable activation method for these.
Re: 88 ramcharger not go into 4wd [Re: buildanother] #1197221
03/15/12 04:07 AM
03/15/12 04:07 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
So what/how activates the vacume?
Wouldnt there be some kind of switch connected to the tranfer case lever?
Any way to bench test?
Thanks a million for the help
1971 charger
Re: 88 ramcharger not go into 4wd [Re: toplescuda] #1197222
03/15/12 05:52 AM
03/15/12 05:52 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Also this being vacume operated that wouldnt cause the lever not to move would it cause this lever wont move at all feels like 4 speed thats hung between two gears????
1971 charger
Re: 88 ramcharger not go into 4wd [Re: toplescuda] #1197223
03/15/12 11:55 AM
03/15/12 11:55 AM
chicagoland,usa
chicagoland,usa
Forget about the vacuum stuff if the lever itself is froze. I would get under there and lube as much linkage as you can, and try to get the linkage moving at the case. It could be an internal issue too, but I've not seen alot of failures like that. I'm assuming again, that the lever also will not go into low range?
Re: 88 ramcharger not go into 4wd [Re: buildanother] #1197224
03/15/12 12:38 PM
03/15/12 12:38 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I had a 88 4wd pickup, but I thought you had to push down on the shifter to get it to move back and forth. I could be wrong, been awhile, long while. But I agree, you have to move the shifter before it signals the front axle to lock together. Spray the bejebees out of the linkage, and see if it moves.
Re: 88 ramcharger not go into 4wd [Re: Dodgeguy101] #1197225
03/15/12 01:37 PM
03/15/12 01:37 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Ivdont know how the 4x4 stuff is on it no instructions heck it has a stupid skull on the lever
1971 charger
Re: 88 ramcharger not go into 4wd [Re: toplescuda] #1197226
03/15/12 01:44 PM
03/15/12 01:44 PM
rockville va.
superbee68 Offline
superbee68  Offline
rockville va.
try backing up while pulling lever
Re: 88 ramcharger not go into 4wd [Re: superbee68] #1197227
03/15/12 03:03 PM
03/15/12 03:03 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
What transmission is in it? Auto, put it in neutral and see if you can move the 4wd shifter, if you can, it will grind some, but you will know the shifter is moving the transfer case. Then put the trans back in gear and move it gently and the transfer case shifter should engage. As I recall, it doesn't move far. If it is a manuel, I always had the truck moving just a little, pushed the clutch in and moved the transfer case shifter. Just have to think of it as 2 transmissions and the transfer case has to be in line just right for it to work. Not exactly the case, but that is the best way to look at it.
If you think it went in 4wd, just go under the truck and try to move the front driveshaft. If it won't turn, the transfer case is in gear, but that doesn't mean the front axle has locked together. The other part is that goob of stuff right over the left tube (drivers side), on the front axle. All that is or does is connect the left side axle together. At least I think it does. Think of it as 2 broken parts, and even if one part is fixed the other will prevent it from actually trying to rotate the front wheels.
I gave that truck to my son who has had it now for 10 years, and it is still going strong. 318 TBI, 4 speed, 3.54 gears. I bought it new in 88, best truck I ever owned.
Re: 88 ramcharger not go into 4wd [Re: Dodgeguy101] #1197228
03/15/12 05:37 PM
03/15/12 05:37 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Ok looked on sun viser says to stop put in netural move lever to engage 4x4 tried that and leved did move not a lot but more then before bout 2-3 inches
1971 charger
Re: 88 ramcharger not go into 4wd [Re: toplescuda] #1197229
03/15/12 05:41 PM
03/15/12 05:41 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Which way did you move it? As I recall back to you left it in high range (normal), and pushing it forward put it into low range.
After it moved did a light come on in the dash? That might tell you it was engaging the front axle, but without checking, who knows.
Re: 88 ramcharger not go into 4wd [Re: Dodgeguy101] #1197230
03/15/12 05:55 PM
03/15/12 05:55 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
It would only come back no light came on i dont think it was far enuff to engage anything just felt like it was hitting something
yes i tried to move it while backing up nothen
at this point not really concerned if it actualy couples the front end because thats vacume has nothen to do with the lever not moving
1971 charger
