Crate questions #1196991
03/14/12 02:31 PM
03/14/12 02:31 PM
Anywhere the British Secret Se...
Moonraker Offline OP
Anyone know the specs on this engine?
http://www.summitracing.com/parts/DCC-5153527/
Could it be built for less than $14000?
Could you run it on the street?
How are they squeezing 470HP out of it??
Re: Crate questions [Re: Moonraker] #1196992
03/14/12 03:15 PM
03/14/12 03:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Crate questions [Re: Moonraker] #1196993
03/14/12 03:22 PM
03/14/12 03:22 PM
NY usa
540challenger Offline
NY usa
Yes you could build it for less if you use a stock 360 or 340 block and RHS. That would cut the cost down big time. Brian from IMM built a buget build that made the same HP for much less cash if i remember.
The that crate motor comes with a race block which is over kill for that HP level unless you plan on upgrading but to spend 12.5G's and ripp into the motor is a little crazy IMO.
470 HP out of a 410 eddy headed motor is no problem.
Re: Crate questions [Re: 540challenger] #1196994
03/14/12 03:45 PM
03/14/12 03:45 PM
NY usa
NY usa
Here is 408 build The only thing missing is the sixpack set up i guess another 1200k for that
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Crate questions [Re: 540challenger] #1196995
03/14/12 04:35 PM
03/14/12 04:35 PM
Thanks for the link thats bada$$! Think I found my next project
Re: Crate questions [Re: 540challenger] #1196996
03/14/12 04:48 PM
03/14/12 04:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
6pk would be closer to 2k.
What heads are on the crate motor ?
Re: Crate questions [Re: JohnRR] #1196997
03/14/12 04:54 PM
03/14/12 04:54 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
P5153849 ~ 2.02 in. Intake/1.600 in. Exhaust, 63cc Chamber
Re: Crate questions [Re: JohnRR] #1196998
03/14/12 05:01 PM
03/14/12 05:01 PM
NY usa
NY usa
6pk would be closer to 2k .
Ya but is should be off-set by the cost of the intake and carb on this engine. jegs prices holley 750 double pumper 385.99, air gap intake 263.99 total 649.98. So at a cost of 2k you would only need 1350 more for a sixpac set up.
Re: Crate questions [Re: JohnRR] #1196999
03/14/12 06:14 PM
03/14/12 06:14 PM
I would like to know this as well
Re: Crate questions [Re: Moonraker] #1197000
03/14/12 07:11 PM
03/14/12 07:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Posted above ...
Re: Crate questions [Re: JohnRR] #1197001
03/14/12 09:12 PM
03/14/12 09:12 PM
NY usa
NY usa
Posted above ...
The heads on the 410 six pack motor should be the alum. moapr performance heads aka the edelbrock LA head with a mopar Logo on them
Re: Crate questions [Re: Moonraker] #1197002
03/15/12 12:41 AM
03/15/12 12:41 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Here's the full specs, as listed in the Mopar Superstore ad. They list it at 450HP/475TQ. I'd say that might be a little "happy" with that size cam and unported heads
Technical Specifications P5153527
Engine type: Chrysler small-block V-8
Part Number: P5153527
Horsepower / Torque: 450 / 475
Displacement (cu in): 410
Bore x stroke (in): 4.04 x 4.00
Block: New R3 cast iron, 4-bolt main caps, dual engine mounts (Magnum & "LA")
Crankshaft: Forged 4340 Stroker
Connecting rods: Forged
Pistons: Custom Diamond Pistons
Camshaft type: Hydraulic
Camshaft lift: .508
Camshaft duration: 248° intake / 248° exhaust
Cylinder heads: "LA" aluminum big valve
Valve size: 2.02intake / 1.60 exhaust
Compression Ratio: 9.7:1
Rocker arms: OEM Style
Rocker arm ratio: 1.6:1
Recommended fuel: 93 octane
Ignition Parts: Mopar Performance Electronic Ignition Kit with Distributor & Wires
Intake Manifold: "LA" Aluminum “Six Pack”
Oil Pump: High volume pump
Oil Pan: 8-Quart Center Sump Street/Strip Oil Pan
Water Pump: Aluminum
Note:
Shown with Optional Available Carburetors.
P4349237 Center
P4349238 Outboard (2)
Free advice and worth every penny...
Factory trained Slinky rewinder.........
