Re: denso altinator upgrade
[Re: stateroadhog]
#1196799
03/14/12 12:17 PM
03/14/12 12:17 PM
RapidRobert
You could run the large output stud to the firewall bulkhead like normal or the Madd bypass run it from the alt (directly) to the starter relay. Not sure how the field wires differ on the Denso compared to Mopar but that's seperate from the bypass conversion
[Re: stateroadhog]
#1196800
03/14/12 12:33 PM
03/14/12 12:33 PM
Posts: 31,036 Oregon
AndyF
If you bought one of my conversion kits then it should have had 4 pages of instructions including a wiring diagram.
