denso altinator upgrade #1196798
03/14/12 08:17 AM
03/14/12 08:17 AM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
Okay I have the altinator and brackets to put on my 440. Read the mad electric page and now am total confused how to wire it. Anyone have a simple diagram to wire it. Thanks
Re: denso altinator upgrade [Re: stateroadhog] #1196799
03/14/12 12:17 PM
03/14/12 12:17 PM
You could run the large output stud to the firewall bulkhead like normal or the Madd bypass run it from the alt (directly) to the starter relay. Not sure how the field wires differ on the Denso compared to Mopar but that's seperate from the bypass conversion
Re: denso altinator upgrade [Re: stateroadhog] #1196800
03/14/12 12:33 PM
03/14/12 12:33 PM
AndyF Offline
AndyF  Offline
If you bought one of my conversion kits then it should have had 4 pages of instructions including a wiring diagram.
Re: denso altinator upgrade [Re: AndyF] #1196801
03/14/12 07:13 PM
03/14/12 07:13 PM
Owosso, Michigan
Owosso, Michigan
It is one of yours I bought it on Craigs list. No instructions with it. Thanks for replying
Re: denso altinator upgrade [Re: stateroadhog] #1196802
03/14/12 08:49 PM
03/14/12 08:49 PM
AndyF Offline
AndyF  Offline
There are some instructions on my website but they aren't as good as the printed ones. PM me your address and I'll mail you a set of instructions.
Re: denso altinator upgrade [Re: AndyF] #1196803
03/14/12 10:57 PM
03/14/12 10:57 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I have one off a 89-90 dodge pickup i could use some instructions / help also
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: denso altinator upgrade [Re: toplescuda] #1196804
03/14/12 11:28 PM
03/14/12 11:28 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I too have an alternator off of a 90 model pickup on my duster. Works great. I used a alternator fusible link for an 06 truck on the large battery stud going to the battery. The other 2 small studs are the field wires and hook them up as you would a normal chrysler alternator. Put the blue wire to one and the green to the other. using your existing voltage regulator. Just make sure to the alternator is grounded good to the block and it should work fine. What ever you do dont use the factory amp gauge for battery power.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: denso altinator upgrade [Re: stateroadhog] #1196805
03/15/12 12:03 AM
03/15/12 12:03 AM
AndyF Offline
AndyF  Offline
