Gas vs Alochol? #1196393
03/13/12 02:58 PM
03/13/12 02:58 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Anyone have any HP/TQ #'s on gas vs alcohol. Motor is a W2 headed 416 @ 11.2CR. Best pass to date on gas is 10.50 @ 126. Jim
Re: Gas vs Alochol? [Re: rt66jim] #1196394
03/13/12 08:35 PM
03/13/12 08:35 PM
okla.
sam64 Offline
sam64  Offline
okla.
it will pickup with alcohol.injected more than carb in my opinion.put a rons flying toilet on it and throttle response on your first burnout with out a rev limiter will scare you.
Re: Gas vs Alochol? [Re: sam64] #1196395
03/13/12 10:23 PM
03/13/12 10:23 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Sam I'm going to put one of these on it. http://www.candsspecialties.com/store/html/054900big.html
Re: Gas vs Alochol? [Re: rt66jim] #1196396
03/13/12 10:28 PM
03/13/12 10:28 PM
okla.
sam64 Offline
sam64  Offline
okla.
i've always wanted to know someone that ran one of those,looks like the e-85 is drying up down here so i may have to go alky.
Re: Gas vs Alochol? [Re: sam64] #1196397
03/13/12 11:07 PM
03/13/12 11:07 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I will have to change my Mallory 4309 regulator to a 4307M. And I shouldbe good to go. Will I need to change the heat range on my plugs? I have never run alcohol. I called Spanky yesterday and he says it should fire right up.
Re: Gas vs Alochol? [Re: rt66jim] #1196398
03/14/12 12:34 AM
03/14/12 12:34 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I just bought one of their 051400 1400 Hi Flow carbs, for my B1 engine It came with 2 1/8th butterflies. Hadn't tried it yet.
Re: Gas vs Alochol? [Re: sam64] #1196399
03/14/12 01:35 AM
03/14/12 01:35 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Thats no lie! Took me 5 burnouts to keep it off the limiter
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Gas vs Alochol? [Re: sam64] #1196400
03/14/12 11:16 AM
03/14/12 11:16 AM
NC
440Jim Offline
440Jim  Offline
NC
I agree.
When I first switched to alky and a Ron's injection, the throttle response was absolutely amazing. Nice torque improvement, consistant, etc.
Re: Gas vs Alochol? [Re: rt66jim] #1196401
03/14/12 11:22 PM
03/14/12 11:22 PM
gregsdart Online content
gregsdart  Online Content
It is hard to figure for a few reasons. Injection gives you less vacuum (restriction) than a carb, and the higher the rpm you build power, the closer the two fuels come. I was told by one engine builder that he could make more power on gas. I never tried it myself, but he is very knowledgeable. In your situation you may see a tenth, maybe as much as three tenths if everything goes in your favor. I gained about a tenth on my switch from Dominator to Terminater, which doubled the airflow at 1.5 inch vacuum. throttle response was impressive. Put it on the bumper the very first pass.
