Re: Gas vs Alochol?
[Re: sam64]
#1196400
03/14/12 11:16 AM
03/14/12 11:16 AM
Posts: 16,928 NC
440Jim
NC
put a rons flying toilet on it and throttle response on your first burnout with out a rev limiter will scare you.
I agree. When I first switched to alky and a Ron's injection, the throttle response was absolutely amazing. Nice torque improvement, consistant, etc.
Re: Gas vs Alochol?
[Re: rt66jim]
#1196401
03/14/12 11:22 PM
03/14/12 11:22 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
It is hard to figure for a few reasons. Injection gives you less vacuum (restriction) than a carb, and the higher the rpm you build power, the closer the two fuels come. I was told by one engine builder that he could make more power on gas. I never tried it myself, but he is very knowledgeable. In your situation you may see a tenth, maybe as much as three tenths if everything goes in your favor. I gained about a tenth on my switch from Dominator to Terminater, which doubled the airflow at 1.5 inch vacuum. throttle response was impressive. Put it on the bumper the very first pass.
