Spacer for crank pulley??? #1196221
03/13/12 03:48 AM
03/13/12 03:48 AM
Tucson, AZ
moparjimm Offline OP
Tucson, AZ
Here's the deal, I'm using a motor plate, so I need to bring my bottom pulley out 3/4" to align with the fan pulley. The total required distance from the balancer to the center of the groove is 2 1/2", can I use a spacer(3/4") too make up the difference? Is there a pulley out there that would work better. The 2 groove billet ones are 2.00/2.85 to center of the grooves. Any ideas???
I thought about using a wheel spacer, the kind w/o studs, would this work? I prefer to use a single groove if at all possible.
Re: Spacer for crank pulley??? [Re: moparjimm] #1196222
03/13/12 04:03 AM
03/13/12 04:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Mancini Racing sells a nice machined 3/8" spacer. I think Andy F makes these? I have not seen any that are 3/4"? You may be able to find a deeper lower pulley. I ran the ATI damper that has the flat front (not recessed like stock) and that pushed my stock pulley too far out, so I ordered a March pulley set for a fluid damper setup, and the lower pulley was 3/8" too shallow. That is why I used the 3/8" spacer listed above, with with longer bolts.
Re: Spacer for crank pulley??? [Re: 451Mopar] #1196223
03/13/12 04:32 AM
03/13/12 04:32 AM
Tucson, AZ
Tucson, AZ
Just checked out the spacers, I would need 2 of them at $44. each, ouch!
thanks
Re: Spacer for crank pulley??? [Re: 451Mopar] #1196224
03/13/12 04:34 AM
03/13/12 04:34 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Normally when using a motor plate sandwiched between the water pump housing & the block the water pump housing gets milled down the thickness of the plate...
Re: Spacer for crank pulley??? [Re: 1_WILD_RT] #1196225
03/13/12 10:12 AM
03/13/12 10:12 AM
Tucson, AZ
Tucson, AZ
Still, expensive and finding the right pulley/spacer would be soooo much easier, thanks for your input though.
Re: Spacer for crank pulley??? [Re: moparjimm] #1196226
03/13/12 12:57 PM
03/13/12 12:57 PM
AndyF Offline
AndyF  Offline
If the motor plate is 3/8 thick then you only need one 3/8 spacer for the crank pulley.
The backside of the water pump housing can also be machined down by 0.375, but then you have to adjust the spacing for any other belt driven accessory.
