swap out 904 tranny to 727 can change yoke on shaft? #1195979
03/12/12 09:40 PM
03/12/12 09:40 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I just swaped from a 904/318 to 4 speed i bought a drive shaft for 727 8 3/4 but as now havent changed the rear what i want to know for sure is can i put the 727 yolk onto the orignal 904 shaft till i swap out the rear?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: swap out 904 tranny to 727 can change yoke on shaft? [Re: toplescuda] #1195980
03/12/12 09:50 PM
03/12/12 09:50 PM
crisfield, maryland 21817
8
82ramIndy493 Offline
You can if the U joints are the same. Mopar used two different U joints. See if both shafts have the same joints. If so the yokes will interchange. If not you can buy a conversion joint that will allow you to put that yoke on the other shaft. I have two of those joints myself and have had to use them on occasions when swapping out center chunks in an 8 3/4.
Re: swap out 904 tranny to 727 can change yoke on shaft? [Re: 82ramIndy493] #1195981
03/12/12 10:14 PM
03/12/12 10:14 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Well i thought so as thought 904/727 tranny were same length that the pig was shorter otn a 8 3/4 them 8 1/4
1971 charger
Re: swap out 904 tranny to 727 can change yoke on shaft? [Re: toplescuda] #1195982
03/12/12 10:18 PM
03/12/12 10:18 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
904 is about 4" or so shorter than a 727, but the 8-1/4 and 8-3/4 are the same length I believe.
Re: swap out 904 tranny to 727 can change yoke on shaft? [Re: slantzilla] #1195983
03/12/12 10:24 PM
03/12/12 10:24 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: swap out 904 tranny to 727 can change yoke on shaft? [Re: MoparforLife] #1195984
03/13/12 12:03 AM
03/13/12 12:03 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Well swaping yoke wont work then
1971 charger
Re: swap out 904 tranny to 727 can change yoke on shaft? [Re: MoparforLife] #1195985
03/13/12 12:10 AM
03/13/12 12:10 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I thought there was like a 1-1 1/2" differance between a 8 1/4 and 8 3/4????
1971 charger
Re: swap out 904 tranny to 727 can change yoke on shaft? [Re: toplescuda] #1195986
03/13/12 07:06 AM
03/13/12 07:06 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There is about 1.75" difference between an 8-3/4 and a 7-1/4. I'm relatively sure 8-1/4 and 8-3/4 are the same.
