Decoding BB water pump housing pt #'s AND starters #1195764
03/12/12 03:50 PM
03/12/12 03:50 PM
SINY
SanityLost Offline OP
SINY
Can someone decode these #'s
I have 3 Water pump housings with the following numbers.
1st-2468007 and on the left side of the housing is 5x25
2nd- 2780987 that is the only number on it
3rd- 2780987-13 and where the bottom hose goes, it has 04019
Now the starters,
1st-2095219
2nd-3755259 05111
3rd-2875553 05102
4th-3755259 05305
Re: Decoding BB water pump housing pt #'s AND starters [Re: SanityLost] #1195765
03/12/12 04:35 PM
03/12/12 04:35 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
first waterpump listed is easy (I have about a dozen) BB 67-71. Chrysler#'s are 2780988/2780989/2951806.
CaN't help with starters, sorry.
Re: Decoding BB water pump housing pt #'s AND starters [Re: DARTH V8Я] #1195766
03/12/12 07:15 PM
03/12/12 07:15 PM
SINY
SINY
No problem appreciate any help I can get
Re: Decoding BB water pump housing pt #'s AND starters [Re: SanityLost] #1195767
03/12/12 08:22 PM
03/12/12 08:22 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Your welcome
starter #2095219 is for a 63-67 'B' engines. Not 100% sure, maybe somebody can confirm?
Re: Decoding BB water pump housing pt #'s AND starters [Re: SanityLost] #1195768
03/12/12 11:20 PM
03/12/12 11:20 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Now the starters,
1st-2095219
2nd-3755259 05111
3rd-2875553 05102
4th-3755259 05305
1st 2468007 is 65 66 361-426
2nd 2780987 is 67-70
3rd 2780987 is 67-70 I believe the 13th revision
Re: Decoding BB water pump housing pt #'s AND starters [Re: RJS] #1195769
03/12/12 11:39 PM
03/12/12 11:39 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
All my 2468007 Iv'e pulled off 383's & 440's.
Re: Decoding BB water pump housing pt #'s AND starters [Re: DARTH V8Я] #1195770
03/13/12 01:36 AM
03/13/12 01:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Big block water pump housings don't care what CID engine they are bolted to , that number is for pre 67 engines , the top bolt for the altenator bracket is in a different spot and the triangle part is different .
Re: Decoding BB water pump housing pt #'s AND starters [Re: JohnRR] #1195771
03/13/12 01:57 AM
03/13/12 01:57 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's a thread I started a while ago, trying to determine some of the finer details of a "correct" application big block water pump housing.
Re: Decoding BB water pump housing pt #'s AND starters [Re: 6bblgt] #1195772
03/13/12 07:55 AM
03/13/12 07:55 AM
SINY
SINY
Thanks guys, so basically run of the mill items. Time for another WIW Post.
