Decoding BB water pump housing pt #'s AND starters
#1195764
03/12/12 03:50 PM
03/12/12 03:50 PM
Posts: 1,947 SINY
SanityLost
SINY
Can someone decode these #'s I have 3 Water pump housings with the following numbers. 1st-2468007 and on the left side of the housing is 5x25 2nd- 2780987 that is the only number on it 3rd- 2780987-13 and where the bottom hose goes, it has 04019 Now the starters, 1st-2095219 2nd-3755259 05111 3rd-2875553 05102 4th-3755259 05305
Re: Decoding BB water pump housing pt #'s AND starters
[Re: SanityLost]
#1195768
03/12/12 11:20 PM
03/12/12 11:20 PM
Posts: 6,224 JERSEY
RJS
JERSEY
1st 2468007 is 65 66 361-426 2nd 2780987 is 67-70 3rd 2780987 is 67-70 I believe the 13th revision
[Re: DARTH V8Я]
#1195770
03/13/12 01:36 AM
03/13/12 01:36 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
All my 2468007 Iv'e pulled off 383's & 440's.
Big block water pump housings don't care what CID engine they are bolted to , that number is for pre 67 engines , the top bolt for the altenator bracket is in a different spot and the triangle part is different .
