Re: Carb float setting, Holley six pack
[Re: Moparnut426]
#1195755
03/12/12 04:12 PM
03/12/12 04:12 PM
RapidRobert
The traditional method is to set the fuel level to where when you rock the eng sideways a bit it dribbles out slightly so on the bench w the carb at the same rake as it is when installed you'd want it a bit lower than where it is now if it's dribbling out untouched
[Re: Moparnut426]
#1195757
03/12/12 04:27 PM
03/12/12 04:27 PM
RapidRobert
not sure if it'll drop or not or if the pump will make up for what the idle circuit uses & as you know the eng uses the least amt of fuel at idle which is why psi is initially checked at idle for a max reading. Just dont want it to get on your paint & ruin it
[Re: Mr.Yuck]
#1195762
03/12/12 05:45 PM
03/12/12 05:45 PM
Posts: 3,916 usa
lewtot184
usa
mine are all set a tad low
setting the end carbs low can create an acceleration hesitation and stalling when coming to a stop. if you look at the end carbs they use a 4bbl secondary float bowl. the secondary 4bbl bowl has a lower float level than the primary to prevent fuel spillover during braking. when the bowl is reversed the lower fuel level can uncover the metering plate main orifices during braking. this creates a lean condition and stalling because the idle circuts are starved for fuel. best bet is to set the fuel levels on all three carbs to the bottom of the sight hole. sometimes the end carbs need to be set slightly higher to prevent the stall condition.
[Re: lewtot184]
#1195763
03/12/12 06:10 PM
03/12/12 06:10 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
never had any of those issues... I run a holley electric pump and it stays on 6psi. I guess if I were to shake the car gas would slosh out. they are juuust at the point where one more hair and they'd drip.
