Page 2 of 4 1 2 3 4
Re: Small block timing chain tensioner- safe to use or not? [Re: Moparnut426] #1195397
03/12/12 03:57 PM
03/12/12 03:57 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
hearing these opinions has just put me right back on the fence lol
The engine was never line honed, so that is not the issue. The timing set was always kinda sloppy from day one. I am looking into a new timing set, just seems like a shame since this one is still in great shape other then a stretched chain (thought about getting a new chain, but unsure of what to do for length).
I too would like to hear more about the tensioners wear characteristics. As the pads wear, isn't that material going to get into the oil like Brian mentioned? Would this not be a possibility for engine failure as a result? or does the pickup screen prevent this?
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195398
03/12/12 04:05 PM
03/12/12 04:05 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Also, I see that Cloyes makes one as well. Is there a difference in quality between the Cloyes one and the factory one? Does anybody know the part number for the factory piece?
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195399
03/12/12 04:13 PM
03/12/12 04:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I put my engine together a few months ago the
factory one was not available... dont remember if it
was on back order or dis continued... I got the Cloyes
Re: Small block timing chain tensioner- safe to use or not? [Re: MR_P_BODY] #1195400
03/12/12 05:02 PM
03/12/12 05:02 PM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
I have run a tensioner on my street and strip 340 for the past 5 years. My block was previously line bored and I could not find a chain that fit tight. Currently upgrading my combo to a 416 and will reuse the same tensioner.
Re: Small block timing chain tensioner- safe to use or not? [Re: gtsdon] #1195401
03/12/12 05:46 PM
03/12/12 05:46 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Your dealer or auto parts store can get you one.
P5007709...same as used on Jeeps...5.2 and 5.9 trucks, and I think the 3.9L.
Keep in mind, timing will only bounce in a case like this at slower or on and off speeds. A timing chain will always have tension against ONE SIDE while under power. Or at least it better. You'll always have a tight side, and one more slack. If its a horrible fitting chain right fromt he beginning, then this could serve as a bandaid. Its funny, you dont see SBC having to run them. Hell, they still successfully use a single roller chain on the late model cams with great success.
As you can see, we dont all agree.... ...its your vehicle, do what makes you comfortable.
RIP Monte Smith
Re: Small block timing chain tensioner- safe to use or not? [Re: CompWedgeEngines] #1195402
03/12/12 06:19 PM
03/12/12 06:19 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
SBC doesnt have the long cam to crank centerline a SBM does either--which is why these engine are hard on timing chains to start with. That said I dont run one...
Re: Small block timing chain tensioner- safe to use or not? [Re: Hot 340] #1195403
03/12/12 06:22 PM
03/12/12 06:22 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
well I just called the dealer with the part number and just like Mr. P said, they don't seem to make them anymore. Was told there are none whatsoever in Canada and that I MIGHT be able to find one from the states. Wonder if the auto parts store would be any different
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195404
03/12/12 06:30 PM
03/12/12 06:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check Summit... thats where I got mine
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195405
03/12/12 06:35 PM
03/12/12 06:35 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
When I ordered my Rollmaster chain, they asked me if I had linehoned the block, I said yes, they asked how much, and made it 3thou shorter, and it fits nice, not to tight, and not to loos, there is zero play in the chain, and I have a lock collar on my distributor shaft to keep my cam gear from bouncing. My timing is ROCK solid.
Kasey
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195406
03/12/12 06:42 PM
03/12/12 06:42 PM
Syracuse,NY
Syracuse,NY
I can get them, drop me a PM.
RIP Monte Smith
Re: Small block timing chain tensioner- safe to use or not? [Re: Moparnut426] #1195407
03/12/12 07:22 PM
03/12/12 07:22 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Here's the wear on mine after a couple thousand miles...
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Small block timing chain tensioner- safe to use or not? [Re: 471Magnum] #1195408
03/12/12 07:45 PM
03/12/12 07:45 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Just called the local parts store and they have this guy for 20 bucks...Doesn't look to reassuring laugh:
http://www.autopartsway.ca/PartDetails.cfm?W0133-1685095/MAH
Todd, Im going to see if my local guy has it since I didn't want to bother him with something this small, but i will shoot you an email if he doesn't
thanks!
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195409
03/12/12 08:04 PM
03/12/12 08:04 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Hughes engines has them. That is where i got mine.
Re: Small block timing chain tensioner- safe to use or not? [Re: Brian Hafliger] #1195410
03/12/12 08:30 PM
03/12/12 08:30 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
When you see how much the nylon wears in such a short time, and it's all in the oil/oil pan you'll never run one again!!
Gimmick if you ask me. Buy a good timing set and be done.
And I agree !! 100%. it is a bandage for junk timing chain set,,
Re: Small block timing chain tensioner- safe to use or not? [Re: VernMotor] #1195411
03/12/12 09:55 PM
03/12/12 09:55 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Small block timing chain tensioner- safe to use or not? [Re: VernMotor] #1195412
03/12/12 09:58 PM
03/12/12 09:58 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I don't know what you guys are doing but my motor has two seasons on it and the wear is minimal. This is with a solid roller too. I am going to put it back in the motor as is too. I also run a good chain but I don't think you can make your timing to steady.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Small block timing chain tensioner- safe to use or not? [Re: VernMotor] #1195413
03/12/12 10:06 PM
03/12/12 10:06 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
This is about SMALL blocks,,,big blocks don't need tensioners/etc..they will still run good with 'sloppy' chains,,,right, Vern.??
If you like drag racing, support your local track.
Re: Small block timing chain tensioner- safe to use or not? [Re: VernMotor] #1195414
03/12/12 10:26 PM
03/12/12 10:26 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Mancini Racing has them for $39.95 part #mopp5007709. I just installed one on my 416. It did not make a difference on how hard or easy the motor turns over. My motor is not back together yet so can't comment on the wear pattern. If you do use one I would degree your cam again with the tensioner on just to see the difference. I tore my motor down with only 800 miles on it because of a vibration. So it gave me a chance to check everything out. I'm using a good quality timing chain and it appeared to have stretched quite a bit, so I'm trying the tensioner. I'm using a gear drive timing set on my 410 so time will tell which one out lasts the other.
I think if you use a good quality oil, regular oil changes, and a good screen on the pick-up tube everything should be fine.
Re: Small block timing chain tensioner- safe to use or not? [Re: krw71ragtop] #1195415
03/12/12 10:59 PM
03/12/12 10:59 PM
Az
Crizila Offline
Crizila  Offline
Az
I have run a Mopar brand ( P5007709 )tensioner for about 3 years now on my 408. No problems and minimal wear. Had the oil pan off once in that time and didn't see anything. Maybe the oil filter caught some stuff.
Fastest 300
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195416
03/12/12 11:01 PM
03/12/12 11:01 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
This is clearly one of those "builders choice" items. I've built them both ways and can't really tell any difference in how they ran. Two things worth considering. One: these tensioners were intended to be used with stock type link chains which have a much smoother back than the double rollers typically used in performance builds. 2nd. If you do decide to use one it may not be a bad idea to drill the 4th. bolt hole in the tensioner [ use a standard cam retainer for a template ] and use a bolt with an 1/8 in. hole drilled through the center in the upper left [ looking at it from the front ] bolt hole. This bolt goes through the front of the block and sits in a pocket in the cam valley that collects oil. This would allow oil to drip directly onto the chain and possibly improve wear.
Page 2 of 4 1 2 3 4
