Re: Small block timing chain tensioner- safe to use or not?
[Re: mshred]
#1195399
03/12/12 04:13 PM
03/12/12 04:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Also, I see that Cloyes makes one as well. Is there a difference in quality between the Cloyes one and the factory one? Does anybody know the part number for the factory piece?
When I put my engine together a few months ago the factory one was not available... dont remember if it was on back order or dis continued... I got the Cloyes
[Re: gtsdon]
#1195401
03/12/12 05:46 PM
03/12/12 05:46 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Your dealer or auto parts store can get you one. P5007709...same as used on Jeeps...5.2 and 5.9 trucks, and I think the 3.9L. Keep in mind, timing will only bounce in a case like this at slower or on and off speeds. A timing chain will always have tension against ONE SIDE while under power. Or at least it better. You'll always have a tight side, and one more slack. If its a horrible fitting chain right fromt he beginning, then this could serve as a bandaid. Its funny, you dont see SBC having to run them. Hell, they still successfully use a single roller chain on the late model cams with great success. As you can see, we dont all agree.... ...its your vehicle, do what makes you comfortable.
RIP Monte Smith
[Re: CompWedgeEngines]
#1195402
03/12/12 06:19 PM
03/12/12 06:19 PM
Posts: 3,395 Pa
Hot 340
Pa
SBC doesnt have the long cam to crank centerline a SBM does either--which is why these engine are hard on timing chains to start with. That said I dont run one...
[Re: mshred]
#1195405
03/12/12 06:35 PM
03/12/12 06:35 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
When I ordered my Rollmaster chain, they asked me if I had linehoned the block, I said yes, they asked how much, and made it 3thou shorter, and it fits nice, not to tight, and not to loos, there is zero play in the chain, and I have a lock collar on my distributor shaft to keep my cam gear from bouncing. My timing is ROCK solid. Kasey
[Re: mshred]
#1195406
03/12/12 06:42 PM
03/12/12 06:42 PM
CompWedgeEngines
Syracuse,NY
I can get them, drop me a PM.
RIP Monte Smith
[Re: Moparnut426]
#1195407
03/12/12 07:22 PM
03/12/12 07:22 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Here's the wear on mine after a couple thousand miles...
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1195408
03/12/12 07:45 PM
03/12/12 07:45 PM
Posts: 3,415 Toronto
mshred
Toronto
Just called the local parts store and they have this guy for 20 bucks...Doesn't look to reassuring laugh: http://www.autopartsway.ca/PartDetails.cfm?W0133-1685095/MAHTodd, Im going to see if my local guy has it since I didn't want to bother him with something this small, but i will shoot you an email if he doesn't thanks!
[Re: Brian Hafliger]
#1195410
03/12/12 08:30 PM
03/12/12 08:30 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
When you see how much the nylon wears in such a short time, and it's all in the oil/oil pan you'll never run one again!! Gimmick if you ask me. Buy a good timing set and be done.
And I agree !! 100%. it is a bandage for junk timing chain set,,
[Re: VernMotor]
#1195413
03/12/12 10:06 PM
03/12/12 10:06 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
This is about SMALL blocks,,,big blocks don't need tensioners/etc..they will still run good with 'sloppy' chains,,,right, Vern.??
If you like drag racing, support your local track.
[Re: mshred]
#1195416
03/12/12 11:01 PM
03/12/12 11:01 PM
Posts: 1,708 S. Il. U.S.A.
5spdcuda
S. Il. U.S.A.
This is clearly one of those "builders choice" items. I've built them both ways and can't really tell any difference in how they ran. Two things worth considering. One: these tensioners were intended to be used with stock type link chains which have a much smoother back than the double rollers typically used in performance builds. 2nd. If you do decide to use one it may not be a bad idea to drill the 4th. bolt hole in the tensioner [ use a standard cam retainer for a template ] and use a bolt with an 1/8 in. hole drilled through the center in the upper left [ looking at it from the front ] bolt hole. This bolt goes through the front of the block and sits in a pocket in the cam valley that collects oil. This would allow oil to drip directly onto the chain and possibly improve wear.
