Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use? #1195352
03/12/12 12:16 AM
03/12/12 12:16 AM
Fort Worth, Texas
xs29j8 Offline OP
xs29j8  Offline OP
Fort Worth, Texas
Are there any big obstacles to using 1971 thru 1974 B or E Body bucket seat cores to redo as 1970 'Cuda seats. Assume that the correct 1970 seat covers, seat backs, seat foam sets, and seat hinge side covers would be used. Essentially, only the metal seat structure would be utilized from the later model car. Are there any year model differences in this seat structure assembly?
Re: Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use? [Re: xs29j8] #1195353
03/12/12 12:21 AM
03/12/12 12:21 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I know 71 works, I think they went to a push button seat back release around 73..
Re: Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use? [Re: 1_WILD_RT] #1195354
03/12/12 12:32 AM
03/12/12 12:32 AM
Fort Worth, Texas
xs29j8 Offline OP
xs29j8  Offline OP
Fort Worth, Texas
Thanks Randy, that opens up options a fair amount. I have a seat with a bent seat back frame, but only have a later model set of spare seat cores (not sure of year model).
Re: Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use? [Re: xs29j8] #1195355
03/12/12 01:08 AM
03/12/12 01:08 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The later seat backs have the covers attached to springs built into the foam. The 70 and maybe 71 have the springs build as part of the frame. So your talking different foam and attachment points for the wires in the covers to pull them tight in the center area. Basically if you look at a bare 70 seat, its not just an open frame like the later ones. The bottoms you can use, but the backs are definetly different.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use? [Re: Silver70] #1195356
03/12/12 01:26 AM
03/12/12 01:26 AM
Fort Worth, Texas
xs29j8 Offline OP
xs29j8  Offline OP
Fort Worth, Texas
Thanks... Sounds like I am limited to 1970 & 1971 seat cores that have the hard plastic seat backs. The 1972 thru 1974 seats have the soft padded vinyl seat backs IIRC...
Re: Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use? [Re: xs29j8] #1195357
03/12/12 01:29 AM
03/12/12 01:29 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
When I said seat backs I meant the seat frame itself, the top seat frame and not the back cover... as far as the back cover, I'm not sure how they attach different. But you are correct in need the earlier top seat frame because of the spring built into the frames and not the foam. I found out the hard way a few years back.
Re: Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use? [Re: Silver70] #1195358
03/12/12 01:46 AM
03/12/12 01:46 AM
Fort Worth, Texas
xs29j8 Offline OP
xs29j8  Offline OP
Fort Worth, Texas
Thanks again... time to place an Ad on the local forum... maybe someone will trade a set of 1970 seat cores for a pair of 1970 RR/GTX fenders that I have...
Re: Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use? [Re: xs29j8] #1195359
03/12/12 08:06 AM
03/12/12 08:06 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Soft backs started in 73.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
