Re: Convert 1971-74 B&E Body Bucket Seats to 1970 Cuda use?
[Re: xs29j8]
#1195353
03/12/12 12:21 AM
03/12/12 12:21 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I know 71 works, I think they went to a push button seat back release around 73..
[Re: 1_WILD_RT]
#1195354
03/12/12 12:32 AM
03/12/12 12:32 AM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
Thanks Randy, that opens up options a fair amount. I have a seat with a bent seat back frame, but only have a later model set of spare seat cores (not sure of year model).
[Re: xs29j8]
#1195355
03/12/12 01:08 AM
03/12/12 01:08 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The later seat backs have the covers attached to springs built into the foam. The 70 and maybe 71 have the springs build as part of the frame. So your talking different foam and attachment points for the wires in the covers to pull them tight in the center area. Basically if you look at a bare 70 seat, its not just an open frame like the later ones. The bottoms you can use, but the backs are definetly different.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1195356
03/12/12 01:26 AM
03/12/12 01:26 AM
xs29j8
Fort Worth, Texas
Thanks... Sounds like I am limited to 1970 & 1971 seat cores that have the hard plastic seat backs. The 1972 thru 1974 seats have the soft padded vinyl seat backs IIRC...
[Re: Silver70]
#1195358
03/12/12 01:46 AM
03/12/12 01:46 AM
xs29j8
Fort Worth, Texas
When I said seat backs I meant the seat frame itself, the top seat frame and not the back cover... as far as the back cover, I'm not sure how they attach different. But you are correct in need the earlier top seat frame because of the spring built into the frames and not the foam. I found out the hard way a few years back.
Thanks again... time to place an Ad on the local forum... maybe someone will trade a set of 1970 seat cores for a pair of 1970 RR/GTX fenders that I have...
[Re: xs29j8]
#1195359
03/12/12 08:06 AM
03/12/12 08:06 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Soft backs started in 73.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
