Milodon Gear Drive.....Need Help!!
#1195195
03/11/12 06:01 PM
03/11/12 06:01 PM
Posts: 3,872 Smyrna, South Carolina
STEFF
Anybody got one that I can come by and have look at it?
Or, Maybe someone that has one, can give me some measurements that I'm looking for?
Re: Milodon Gear Drive.....Need Help!!
[Re: STEFF]
#1195200
03/12/12 11:53 PM
03/12/12 11:53 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I just sold one to Dragula
home of the Sox and Martin Hemi Duster
[Re: reknapp52]
#1195201
03/13/12 12:16 AM
03/13/12 12:16 AM
STEFF
I have one on the shelf at my shop--what dimension do you need?
Here Goes:
1) Center of tooth to center of tooth (tooth spacing, also known as circular pitch) on cam gear
2) Pitch Diameter of Cam Gear, Idler Gear & Crank Gear {measure from middle of tooth to middle of tooth, across center of gear)
3) Thickness of Cam Gear, Idler Gear & Crank Gear
4) Back side of Cam Gear to Cam Hub Mtg. face on Gear
5) Outside Diameter of Cam Gear, Idler Gear & Crank Gear
Which model do you have?
Thanx!!
