Milodon Gear Drive.....Need Help!! #1195195
03/11/12 06:01 PM
03/11/12 06:01 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Anybody got one that I can come by and have look at it?
Or, Maybe someone that has one, can give me some measurements that I'm looking for?
Re: Motor City Moparts Guys.....Milodon Gear Drive..... [Re: STEFF] #1195196
03/11/12 06:28 PM
03/11/12 06:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Steff I have a KB gear drive... the one MP sells...
dont know how different it is
Re: Milodon Gear Drive.....Need Help!! [Re: STEFF] #1195197
03/12/12 11:17 PM
03/12/12 11:17 PM
STEFF Offline OP
STEFF  Offline OP
OK........Does anyboody have a Milodon Gear Drive that can give me some dims I'm looking for?
Thanx Mikey, but need a Milodon.
Re: Milodon Gear Drive.....Need Help!! [Re: STEFF] #1195198
03/12/12 11:19 PM
03/12/12 11:19 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
all of mine are bolted to engines. I have my 512 on a stand with one installed. Do you need outside dims?
Re: Milodon Gear Drive.....Need Help!! [Re: STEFF] #1195199
03/12/12 11:32 PM
03/12/12 11:32 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
I have one on the shelf at my shop--what dimension do you need?
Re: Milodon Gear Drive.....Need Help!! [Re: STEFF] #1195200
03/12/12 11:53 PM
03/12/12 11:53 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I just sold one to Dragula
home of the
Sox and Martin Hemi Duster
Re: Milodon Gear Drive.....Need Help!! [Re: reknapp52] #1195201
03/13/12 12:16 AM
03/13/12 12:16 AM
STEFF Offline OP
STEFF  Offline OP
Here Goes:
1) Center of tooth to center of tooth (tooth spacing, also known as circular pitch) on cam gear
2) Pitch Diameter of Cam Gear, Idler Gear & Crank Gear {measure from middle of tooth to middle of tooth, across center of gear)
3) Thickness of Cam Gear, Idler Gear & Crank Gear
4) Back side of Cam Gear to Cam Hub Mtg. face on Gear
5) Outside Diameter of Cam Gear, Idler Gear & Crank Gear
Which model do you have?
Thanx!!
Re: Milodon Gear Drive.....Need Help!! [Re: STEFF] #1195202
03/15/12 11:27 PM
03/15/12 11:27 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
I'll try to take a look at it and get the dimensions off it this weekend. I'll also look for the model number. It came on a Modified Production Hemi motor that I bought back in 1978.
Re: Milodon Gear Drive.....Need Help!! [Re: reknapp52] #1195203
03/16/12 05:58 PM
03/16/12 05:58 PM
STEFF Offline OP
STEFF  Offline OP
Don't sweat it. I got the info I needed. Thanx any way, though.
