Re: Tuning issues
[Re: 73rrak]
#1194830
03/11/12 02:48 AM
03/11/12 02:48 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
vacuum advance hooked up??? What is the in gear idle vacuum? and when does it ping under real light throttle acceleration.
Re: Tuning issues
[Re: 73rrak]
#1194832
03/11/12 09:40 AM
03/11/12 09:40 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
What rpm is it pinging at during the medium accel?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Tuning issues
[Re: 73rrak]
#1194833
03/11/12 11:17 AM
03/11/12 11:17 AM
RapidRobert
You said stock springs (1 heavy with a long elongated loop + a light spring). I believe you need more octane. your timing is retarded, plugs are cold, jets are way rich, no extra vac adv timing: there's nothing much else you can alter
