PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED
#1194246
03/10/12 12:12 AM
03/10/12 12:12 AM
Posts: 1,039 ALBERTA CANADA
CUDA8U
ALBERTA CANADA
I HAVE A 440 BORED 30 OVER,ROSS FLAT TOP FORGED PISTONS,MOPAR PERF SINGLE PLANE INTAKE 600 EDDY COMBO,C.A.T H RODS
HEADS ARE PORTED AND POLISHED,2.14/1.81 STAINLESS VALVES,HYDRAULIC CAM SPRINGS GOOD UP TO .550 LIFT,250CFM@.500 LIFT.
COMP CAMS ,21-224-4 XTREME ENERGY DUR 274/286 LIFT .488/491 HYDRAULIC FLAT TAPPET
PLS FEEL FREE TO GIVE ADVICE ON ANY PERFORMANCE UPGRADES THAT WOULD GREATLY IMPROVE HP/TQ NUMBERS IN A STREET CAR ,THE CAR HAS FRAME CONNECTORS,TORQUE STRAP,2800 TCI STALL WITH A 411 POSI BUT WOULD LIKE TO CHANGE TO A 3:55,STAGE 2 SHIFT KIT
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED
[Re: Dodgem]
#1194250
03/10/12 01:09 AM
03/10/12 01:09 AM
CUDA8U
ALBERTA CANADA
You message is mixed you want to put a more streetable gear in but gain a bunch of HP and TQ and at the same time still use the 2800 stall I presume??
Stoker
basically i want to know if this combo is performing to its full potential or is there a cam,carb,intake combo that would let it perform to its full potential
[Re: mr_340]
#1194251
03/10/12 01:10 AM
03/10/12 01:10 AM
CUDA8U
ALBERTA CANADA
I hope the springs are good to .550" lift instead of .055" lift.
ok we all know you're perfect and never make a typo....thanks
[Re: RUNCHARGER]
#1194254
03/10/12 05:42 AM
03/10/12 05:42 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Put a good carb on it, make sure your fuel system is up to snuff, ensure the distributor has a good ignition curve in it. Leave the gears.
Sheldon
YOU NEED A GOOD HOLLEY.
[Re: RemCharger]
#1194255
03/10/12 10:44 AM
03/10/12 10:44 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I see heads are ported and polished but what heads are they and what is the comp ratio ? Ron
[Re: 383man]
#1194258
03/10/12 04:28 PM
03/10/12 04:28 PM
CUDA8U
ALBERTA CANADA
I see heads are ported and polished but what heads are they and what is the comp ratio ? Ron [/quote
I listed all info from previous owner on another post
I just received this car and with snow still lingering i haven't been able to run it on the open road and this why i am looking for any suggestions on mods to engine from pro builders since i am not
Thanks for all your input guys
