PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED #1194246
03/10/12 12:12 AM
03/10/12 12:12 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
I HAVE A 440 BORED 30 OVER,ROSS FLAT TOP FORGED PISTONS,MOPAR PERF SINGLE PLANE INTAKE 600 EDDY COMBO,C.A.T H RODS
HEADS ARE PORTED AND POLISHED,2.14/1.81 STAINLESS VALVES,HYDRAULIC CAM SPRINGS GOOD UP TO .550 LIFT,250CFM@.500 LIFT.
COMP CAMS ,21-224-4 XTREME ENERGY DUR 274/286 LIFT .488/491 HYDRAULIC FLAT TAPPET
PLS FEEL FREE TO GIVE ADVICE ON ANY PERFORMANCE UPGRADES THAT WOULD GREATLY IMPROVE HP/TQ NUMBERS IN A STREET CAR ,THE CAR HAS FRAME CONNECTORS,TORQUE STRAP,2800 TCI STALL WITH A 411 POSI BUT WOULD LIKE TO CHANGE TO A 3:55,STAGE 2 SHIFT KIT
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: CUDA8U] #1194247
03/10/12 12:24 AM
03/10/12 12:24 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like a pretty serious set up but why are you yelling?
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: CUDA8U] #1194248
03/10/12 12:33 AM
03/10/12 12:33 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You message is mixed you want to put a more streetable gear in but gain a bunch of HP and TQ and at the same time still use the 2800 stall I presume??
Stoker
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: Dodgem] #1194249
03/10/12 12:42 AM
03/10/12 12:42 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I hope the springs are good to .550" lift instead of .055" lift.
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: Dodgem] #1194250
03/10/12 01:09 AM
03/10/12 01:09 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
Stoker
basically i want to know if this combo is performing to its full potential or is there a cam,carb,intake combo that would let it perform to its full potential
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: mr_340] #1194251
03/10/12 01:10 AM
03/10/12 01:10 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
ok we all know you're perfect and never make a typo....thanks
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: CUDA8U] #1194252
03/10/12 01:13 AM
03/10/12 01:13 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Put a good carb on it, make sure your fuel system is up to snuff, ensure the distributor has a good ignition curve in it. Leave the gears.
Sheldon
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: RUNCHARGER] #1194253
03/10/12 02:57 AM
03/10/12 02:57 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello I would put a 509 cam in and go with a 850 Holley DP Carb.3"EXHAUST all the way back, You can get the cam at your local Mopar dealer for around $200.00 I run this cam in all of my big blocks and it always works great and makes lots of HP AT TOP END.
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: RUNCHARGER] #1194254
03/10/12 05:42 AM
03/10/12 05:42 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Sheldon
YOU NEED A GOOD HOLLEY.
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: RemCharger] #1194255
03/10/12 10:44 AM
03/10/12 10:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I see heads are ported and polished but what heads are they and what is the comp ratio ? Ron
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: CUDA8U] #1194256
03/10/12 12:54 PM
03/10/12 12:54 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Take a pill, Noob.
That is uncalled for on a forum that provides the best advice you are ever going to get.
Mo' Farts
Moderated by "tbagger".
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: CUDA8U] #1194257
03/10/12 01:57 PM
03/10/12 01:57 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Have you run it at the track yet? With traction you should be into the 12's although I don't know if that carb would get you there.
Sheldon
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: 383man] #1194258
03/10/12 04:28 PM
03/10/12 04:28 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
I see heads are ported and polished but what heads are they and what is the comp ratio ? Ron [/quote
I listed all info from previous owner on another post
I just received this car and with snow still lingering i haven't been able to run it on the open road and this why i am looking for any suggestions on mods to engine from pro builders since i am not
Thanks for all your input guys
Re: PRO ENGINE BUILDERS THOUGHTS AND SUGGESTIONS NEEDED [Re: CUDA8U] #1194259
03/10/12 04:38 PM
03/10/12 04:38 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Ahh okay. Check your timing and get back to us. Whats the initial timing set at, how much total advance and what RPM is it all in at?
Throw that carb in the garbage, Personally I would buy a Holley 3310 but it won't run optimal by just bolting it on. If there is a guy near you that has a good reputation with Holley carbs I would have him tune it for you.
Don't change anything else until what you have is tuned to give all it's got.
One other thing, what does it have for a fuel pump and lines? I would install a fuel pressure gauge at least temporarily, when you start driving the car you'll want to tape it to the cowl and make sure your pressure doesn't drop when it's wooded in high gear.
Sheldon
