Re: Brad Penn oil....
[Re: cdp]
#1192987
03/07/12 08:03 PM
03/07/12 08:03 PM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
Good stuff, I use it in everything. Not much margin in the stuff to justify the shipping. IMO get it from Summit Racing.
[Re: cdp]
#1192988
03/07/12 08:13 PM
03/07/12 08:13 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Its all i'll use in any engine i build. I'd love to sell you some, but it would be crazy to ship several cases. Find someone in your area that handles it. If you cant find someone,drop me a pm and Ill see if i can find another dealer or distributor near you.
RIP Monte Smith
[Re: cdp]
#1192991
03/07/12 10:16 PM
03/07/12 10:16 PM
Posts: 7,664 IN
ahy
IN
What viscosity should I buy for the midwest. All 440's 6V's and 383 HP's. My 383 RR I hope to drive the wheels off of! No driving during the winter.
10/30 10/40
I did find a place in KCK and Marshall, MO that are distributors.
Let your engine(s) tell you what weight likes... if hot oil presure is good with 10W30 than that's what I'd run. If a little low, run the 10W40. Generally engines built with stock or near stock clearance do fine on 10W30. Engines with hi-po clearances may like the 10W40, especially if you do street driving that may force you to idle while hot for a while.
[Re: cdp]
#1192993
03/08/12 01:40 AM
03/08/12 01:40 AM
Posts: 295 Greensburg, Pa
Mpetros
Greensburg, Pa
Good Stuff! We are a Dealer at Work.. $60.00 a Single Case, We give discounts on volume..Depending on where you are at Shipping will vary.. Call or Shoot Me Your Zip and I can Figure Shipping.. Then You can decide whether or not it would be worth it.. Mark 724-837-8233 www.GreensburgMachine.Com
[Re: cdp]
#1192994
03/08/12 11:51 AM
03/08/12 11:51 AM
Posts: 3,441 Mo.
supercomp
Mo.
[Re: Kudakidd]
#1192997
03/08/12 07:43 PM
03/08/12 07:43 PM
Posts: 5,875 communist bloc of new jersey
jamesc
and to think this was just Kendall GT-1. And it sold at $3 a quart!
and guess what, GT-1 was the EXACT same oil that was in the dual action bottle sans the green dye. how can i say this.... i was running the filler.
[Re: jamesc]
#1192998
03/08/12 08:08 PM
03/08/12 08:08 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Never made the connection of GT-1 and the BradPenn...I ran GT-1 back in '68. I checked my oil one day at the track after a run,,FOAM clear up the dip-stick..!! I IMEDIATELY quit running GT-1. As for the Brad Penn stuff,,I have had several people tell me they cannot keep the oil in their motors. Most running dry sump set-ups, with NO leaks anywhere, but the oil level is LOW quickly.
If you like drag racing, support your local track.
[Re: supercomp]
#1192999
03/09/12 12:06 PM
03/09/12 12:06 PM
Posts: 3,691 MO
cdp
MO
Where in Missouri.
In Holden, just 30 miles east of KC.
Is there much difference running Brad Penn compared to running...say Castrol with ZDD-Plus in it instead?
Thats what I did on initial fire up on a 383 for a 71-RR I'm putting together.
[Re: jamesc]
#1193003
03/12/12 11:45 AM
03/12/12 11:45 AM
Posts: 3,746 Riverside, California
Lil Demon
The BP oil is not dyed green - the green oil is unique to that particular well in Bradford, Pennsylvania (hence the name Brad Penn).
I've never had a foaming problem with it and have run it exclusively for ~7 years. Also sold about 2000 cases of the stuff to customers and never had a single complaint.
