Re: Cost to do break in on engine dyno?
[Re: Madcoy]
#1192967
03/08/12 01:36 AM
03/08/12 01:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
For JUST a break in on the dyno I would think they would charge $350 or about that... being that they have to mount it and all, your better off doing a full day
[Re: quickd100]
#1192969
03/08/12 09:38 AM
03/08/12 09:38 AM
Posts: 1,051 The Great White North
RAMM
I charge $400.00 CDN for 5 hrs on the dyno. Others in my area charge about the same onup to $700 for the day. It's always worth it--There are things found on the dyno that you would never find in the car. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: Madcoy]
#1192970
03/08/12 10:03 AM
03/08/12 10:03 AM
Posts: 13,401 Marion, South Carolina [><]
an8sec70cuda
$600 for a day on the dyno here. Like said before, you'd be better off doing the day and make some pulls. All the time is in setup.
Or you could build a cheap engine test stand to have at home like I did.
[Re: tboomer]
#1192974
03/08/12 11:55 AM
03/08/12 11:55 AM
Posts: 4,086 The Wet Coast, Canada
megajoltman
Hey RAMM where are you located?
I paid about $400 a day quite a few years ago, was sure worth it when I bent a valve and didn't have to remove it from my car to fix.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: Dunnuck Racing]
#1192977
03/08/12 12:32 PM
03/08/12 12:32 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
A lot of guys on a budget won't spend the extra money for dyno break-ins or testing,which is a shame. The closest guy to me was charging $400.00 to break it in and make one power pull and no tuning. The shop I bought my dyno from was charging $300.00 for a break in and told me guys would get all excited seeing the engine on the dyno and want power numbers,so he would charge them another $300.00 just to make a few pulls. I offer half day(4 hour) sessions for $250.00,and will do break ins,power pulls,whatever time will allow. $400.00 will get a full day(8 hour)session. I will probably offer even further discounts at times. I mainly am offering this to help out the average bracket racer,as a lot can be learned. Keith
I agree with Keith 100%, there is so much to be learned about your motor. I had HemiRam's 512 on last winter and he ended up with a bad carb, and a leaking rear seal. If he'd tryed to break it in, in the car some real bad things would have happened. From what I've seen on average you can usually pick up 45-50hp tuning it on the dyno from start to finish.Dave
[Re: quickd100]
#1192978
03/08/12 12:52 PM
03/08/12 12:52 PM
Posts: 165 Edmond, Oklahoma. U.S.A.
Madcoy
That is exactly what I am thinking!! I have a completely new car front to rear. I have a couple of these to do. The first one is small block stroked 360. My concern is cam break in and how my trans is going to react. As well as seals and the such. I would like to get the new rubbed off and then maybe do some tweaking. A whole day sounds like the way to go. And $500 is not a bad price for piece of MIND!!! Now just to find someone in Oklahoma City? But I am probably headed to Duncan.
My American PitBull is smarter than your Poodle
