Timing with vacuum advance #1192953
03/07/12 06:27 PM
03/07/12 06:27 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I'm new to tuning with vacuum advance and I have a few questions. I shortened my mechanical advance slots to .375. I set my initial to 16 (vacuum unplugged) and get a total of 32 ( vacuum unplugged). When I connect the vacuum advance my initial goes to about 20 and my total goes to about 40. I haven't driven it yet but it idles pretty good with the vacuum unplugged and idles like crap with the vacuum plugged in. Does anybody have any info to post that would help me or feel like taking the time to walk me thru this ?
Re: Timing with vacuum advance [Re: 73rrak] #1192954
03/07/12 06:32 PM
03/07/12 06:32 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
hooked to wrong port
Re: Timing with vacuum advance [Re: 73rrak] #1192955
03/07/12 06:32 PM
03/07/12 06:32 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Sounds like you're plugging it in to manifold vacuum. Try ported vacuum instead.
Re: Timing with vacuum advance [Re: jbc426] #1192956
03/07/12 06:37 PM
03/07/12 06:37 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
It's connected to the passenger side of the front metering block of my 800 Holley. Is this right or wrong ?
Re: Timing with vacuum advance [Re: 73rrak] #1192957
03/07/12 07:27 PM
03/07/12 07:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
DOES IT HAVE VACCUM AT IDLE?
Re: Timing with vacuum advance [Re: 73rrak] #1192958
03/07/12 08:19 PM
03/07/12 08:19 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Depending on the metering block, sometimes it ported vacuume, sometimes not. As suggested, just start the engine let it idle and see if theres suction at the port. If there is, maybe another source somewhere on the carb.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Timing with vacuum advance [Re: DARTH V8Я] #1192959
03/07/12 10:03 PM
03/07/12 10:03 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
It does have vacuum at idle and it's the only port it has on the carb besides the ones on the base plate. I disconnected the vacuum advance and drove it and it runs great so I think I will just leave it disconnected for now. I put up another post about my coil terminal smoking almost sounds like I'm still chasing gremlins.
Re: Timing with vacuum advance [Re: 73rrak] #1192960
03/07/12 10:24 PM
03/07/12 10:24 PM
there's gotta be a ported nipple on there somewhere. that or the throttle plate is opened to far @idle
