70 Hp Manifold Exhaust Pipe #1192724
03/07/12 09:53 AM
03/07/12 09:53 AM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
I am reassembling my roadunner and will be using the stock hp manifolds, the old system was headers and rotted exhaust. I need to buy a new exhaust system and am shopping around, the one peice I asm missing though is the section of pipe that goes from the exhaust manifold flange to the staright pipe under the car. Is this a custom bent of fab part or can I purchase it as a seperate piece somewhere.
thanks
Re: 70 Hp Manifold Exhaust Pipe [Re: 454Baja] #1192725
03/07/12 10:05 AM
03/07/12 10:05 AM
NE
bigtail Offline
bigtail  Offline
NE
You might check with tti. They make downpipes in original configurations for people that don't want to run headers. They make what I want/need for my e-body.
This page is made up completely of recycled electrons.
Re: 70 Hp Manifold Exhaust Pipe [Re: bigtail] #1192726
03/07/12 10:46 AM
03/07/12 10:46 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
Accrurate LTD
5549 post on old board
Re: 70 Hp Manifold Exhaust Pipe [Re: 454Baja] #1192727
03/07/12 11:02 AM
03/07/12 11:02 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just an FYI the picture you have attached is that of the tail pipe , the end you drew the blue line on wit hthe 90* angle is the end that goes to the tip at the rear bumper.
You can buy a complete exh system from a few sources , some are more $$ than others .
Re: 70 Hp Manifold Exhaust Pipe [Re: bigtail] #1192728
03/07/12 12:06 PM
03/07/12 12:06 PM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
thank you
that is what I am looking for, the picture was illustarted wrong but the idea came across
Re: 70 Hp Manifold Exhaust Pipe [Re: 454Baja] #1192729
03/07/12 02:40 PM
03/07/12 02:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
That picture is incorrect for "stock" also. A '70 Road Runner with a 383 would have one pipe each side up to the mufflers. A 440 (440 4bbl in a Superbird & 440 6bbl cars) would have a "H" pipe, 1 piece that went from the manifolds to the mufflers.
