Re: Is this an engine builder's Trick?
[Re: B G Racing]
#1192329
03/06/12 03:50 PM
03/06/12 03:50 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
We used to drill the valley for oil drain back,but with the advent of better oil systems we find it unnecessary,heck we used to polish the lifter valley before we knew better.
Wow! That must have been a project!
[Re: B G Racing]
#1192331
03/06/12 06:41 PM
03/06/12 06:41 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I looked at those mods about 3 decades ago and thought to myself, "that's a lot of work for nothing." So I've never done them. I do remove the casting flash though, just in case something might break off.
[Re: Guitar Jones]
#1192332
03/06/12 07:12 PM
03/06/12 07:12 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Never thought to drill that area out. once the oil hits that and fills it up...I always just consider it to be "lost oil" it stays there forever. as fresh oil drains from the heads, it keeps the puddles "fresh" so after the initial fire up/cam break in and oil change, you never know the difference.
**Photobucket sucks**
[Re: gregsdart]
#1192337
03/06/12 09:11 PM
03/06/12 09:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not drilling them provides a place for some of the trash from my broken rocker arm needle bearings to collect! Better than running the stuff through the oil pump!
I still glue screen over ALL the openings on the top
[Re: CHAPPER]
#1192338
03/06/12 09:12 PM
03/06/12 09:12 PM
MR_P_BODY
I still drill those holes in a wet sump system.. in a dry sump you have a pick up up there
What dont you understand
