Is this an engine builder's Trick? #1192325
03/06/12 03:01 PM
03/06/12 03:01 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
My other 400 and 383 blocks don't have these drilled out.
Is it just an engine builder's trick?
Re: Is this an engine builder's Trick? [Re: GwaiiEagle] #1192326
03/06/12 03:13 PM
03/06/12 03:13 PM
It use to be, I don't do it any more It allows most of the oil caught in each depression to drain back faster instead of storing it in the valley when shut off
Re: Is this an engine builder's Trick? [Re: Cab_Burge] #1192327
03/06/12 03:47 PM
03/06/12 03:47 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We used to drill the valley for oil drain back,but with the advent of better oil systems we find it unnecessary,heck we used to polish the lifter valley before we knew better.
Re: Is this an engine builder's Trick? [Re: B G Racing] #1192328
03/06/12 03:49 PM
03/06/12 03:49 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
And paint the lifter valley with high gloss slick paint. Anything to get that oil back in the pan.
Re: Is this an engine builder's Trick? [Re: B G Racing] #1192329
03/06/12 03:50 PM
03/06/12 03:50 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Wow! That must have been a project!
Re: Is this an engine builder's Trick? [Re: bobs66440] #1192330
03/06/12 03:58 PM
03/06/12 03:58 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
As we get older,we "sometimes" get wiser sometimes
Re: Is this an engine builder's Trick? [Re: B G Racing] #1192331
03/06/12 06:41 PM
03/06/12 06:41 PM
Guitar Jones Offline
I looked at those mods about 3 decades ago and thought to myself, "that's a lot of work for nothing." So I've never done them. I do remove the casting flash though, just in case something might break off.
Re: Is this an engine builder's Trick? [Re: Guitar Jones] #1192332
03/06/12 07:12 PM
03/06/12 07:12 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Never thought to drill that area out. once the oil hits that and fills it up...I always just consider it to be "lost oil" it stays there forever. as fresh oil drains from the heads, it keeps the puddles "fresh" so after the initial fire up/cam break in and oil change, you never know the difference.
**Photobucket sucks**
Re: Is this an engine builder's Trick? [Re: 70Cuda383] #1192333
03/06/12 07:17 PM
03/06/12 07:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I still drill those holes in a wet sump system..
in a dry sump you have a pick up up there
Re: Is this an engine builder's Trick? [Re: MR_P_BODY] #1192334
03/06/12 08:16 PM
03/06/12 08:16 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
My new builds block is drilled like that too. With the cam in, it appears some of the reasoning besides drain back, is to drip oil on the cams lobes. Kind of like a poormans lifter EDM. Mines drilled from front to back.
Re: Is this an engine builder's Trick? [Re: MR_P_BODY] #1192335
03/06/12 09:00 PM
03/06/12 09:00 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If you like drag racing, support your local track.
Re: Is this an engine builder's Trick? [Re: GwaiiEagle] #1192336
03/06/12 09:07 PM
03/06/12 09:07 PM
gregsdart Offline
gregsdart  Offline
Not drilling them provides a place for some of the trash from my broken rocker arm needle bearings to collect!
Better than running the stuff through the oil pump!
Re: Is this an engine builder's Trick? [Re: gregsdart] #1192337
03/06/12 09:11 PM
03/06/12 09:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I still glue screen over ALL the openings on the top
Re: Is this an engine builder's Trick? [Re: CHAPPER] #1192338
03/06/12 09:12 PM
03/06/12 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What dont you understand
Re: Is this an engine builder's Trick? [Re: MR_P_BODY] #1192339
03/06/12 09:33 PM
03/06/12 09:33 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Where do you locate the pick-up/suction, with a dry sump, that gets those little areas of oil between the lifters?
Re: Is this an engine builder's Trick? [Re: Sport440] #1192340
03/06/12 09:36 PM
03/06/12 09:36 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
It would do that any how after the puddle fills, it has to spill over somewhere..
I personally think its worth the time to do the extra little stuff. Doesnt really cost much extra.
Re: Is this an engine builder's Trick? [Re: Bob_Coomer] #1192341
03/06/12 10:21 PM
03/06/12 10:21 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Sure it would spill over anyways, randomly. But the hole sure would help direct the oil better.
I think its worth the time too I liked the idea/concept after looking at it.
Re: Is this an engine builder's Trick? [Re: CHAPPER] #1192342
03/06/12 11:04 PM
03/06/12 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well on a dry sump block all of the valley is sealed
off so yes you need a pick up up there but you also
carry ALOT more oil in the tank so that bit that is
lost up there doesnt matter but on a wet sump you run
less oil so why let that bit lay up there doing nothing
so thats why I still drill the holes
Re: Is this an engine builder's Trick? [Re: MR_P_BODY] #1192343
03/08/12 02:09 AM
03/08/12 02:09 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Makes perfect sense to me! I agree 100% with Mike's(Sport440) assessment of the drilled hole acting like an EDM solid lifter! The oil dripping through the drilled holes is aimed more directly onto the cam lobes...instead of just a random over-flow!
Re: Is this an engine builder's Trick? [Re: B G Racing] #1192344
03/08/12 12:41 PM
03/08/12 12:41 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I heard that's not the only thing you were polishing
home of the
Sox and Martin Hemi Duster
