Window net rules changed again as of 03/05/12 #1192199
03/06/12 12:29 PM
03/06/12 12:29 PM
Illinois, Indiana, Louisiana
ProStDodge Offline OP
NHRA has changed its thoughts on the window net rule for cars slower than 7.49 (4.50). The section in RED has been REMOVED and replaced by the section in BLUE.
SECTION 20: GENERAL REGULATIONS, INTERIOR: 6, WINDOW NET (Page 29) (3/5/2012) An SFI 27.1 ribbon-type or mesh-type window net is mandatory on any full-bodied car required by the rules to have a roll cage. An SFI 27.1 ribbon-type or mesh-type window net is mandatory on any full-bodied car running 7.49 (*4.49) or quicker. For full-bodied cars running 7.50 (*4.50) to 9.99 (*6.39) or if vehicle runs 135 mph or faster a ribbon-type or SFI 27.1 mesh-type window net is mandatory unless otherwise specified by class requirements. SFI 27.1 window net, when required, must be updated at two-year intervals from the date of manufacture. Window net must be securely mounted on the inside of the roll cage, with the permanent attachment at the bottom. All attachment points must be designed in an attempt to protect the driver and avoid contact with track surface or guardwall. Eyelet clips, dogleash hardware, hose clamps, etc. prohibited. Penetration of webbing, except as performed by manufacturer, prohibited. Any modification to net must be performed by manufacturer.
NHRA members can find this information in the "Rulebook amendments" section on the www.nhraracer.com site.
This change means the SFI ribbon style nets are not needed until you run faster than 7.49. So you don't need to be changing your ribbon net every 2 years, unless you have a mesh style net, or run faster than 7.49 (4.50)
Scott
Re: Window net rules changed again as of 03/05/12 [Re: ProStDodge] #1192200
03/06/12 12:36 PM
03/06/12 12:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As usual someone is on the ball with changes. Some of us have already run two divisional races and purchased new stuff. Oh well it looks so much better than the perfectly good one it replaced
Re: Window net rules changed again as of 03/05/12 [Re: Al_Alguire] #1192201
03/06/12 12:38 PM
03/06/12 12:38 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
do i detect a hint of sarcasm there Al?
Re: Window net rules changed again as of 03/05/12 [Re: jamesc] #1192202
03/06/12 12:50 PM
03/06/12 12:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
From me...No way
Re: Window net rules changed again as of 03/05/12 [Re: ProStDodge] #1192203
03/06/12 12:56 PM
03/06/12 12:56 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
7.50-9.99 window net mandatory, sfi 27.1 still says updated every 2 years, am i missing something, only had 1 coffee so far
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Window net rules changed again as of 03/05/12 [Re: 440lebaron] #1192204
03/06/12 12:59 PM
03/06/12 12:59 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
It says a ribbon type or an SFI mesh type
Re: Window net rules changed again as of 03/05/12 [Re: SB412DUSTER] #1192205
03/06/12 01:09 PM
03/06/12 01:09 PM
tboomer Online work
tboomer  Online Work
Yet another good reason to stay above 9.99..
Re: Window net rules changed again as of 03/05/12 [Re: tboomer] #1192206
03/06/12 01:25 PM
03/06/12 01:25 PM
NC
440Jim Offline
440Jim  Offline
NC
I hope I can still cancell my back order for a new window net. My current ribbon type is only 2 years old.
I hate spending money on something of no benefit and no longer required.
EDIT: Summit was able to cancel my backorder. This was ordered on 2/7, first delay to 3/3, then to 3/11. Evidently a lot of people were ordering these, many more than more years. Likely due to the NHRA rule mess.
Re: Window net rules changed again as of 03/05/12 [Re: 440Jim] #1192207
03/06/12 01:38 PM
03/06/12 01:38 PM
PA
moparacer Offline
moparacer  Offline
PA
Too late for me. Already redone my mount, purchased a new ribbon net and canned a perfectly good mesh net.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Window net rules changed again as of 03/05/12 [Re: 440Jim] #1192208
03/06/12 01:41 PM
03/06/12 01:41 PM
Guitar Jones Online laugh2
Well I guess not having money has it's privileges.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Window net rules changed again as of 03/05/12 [Re: Guitar Jones] #1192209
03/06/12 03:20 PM
03/06/12 03:20 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Eliminates confusion as to whether or not a 10 sec car with cage needs a net.
Not me being confused... tech directors...
Re: Window net rules changed again as of 03/05/12 [Re: RemCharger] #1192210
03/06/12 05:15 PM
03/06/12 05:15 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
I think I will stay with my new RCI $23 ribbon net, it has better luck so far.
Re: Window net rules changed again as of 03/05/12 [Re: ProStDodge] #1192211
03/07/12 01:02 AM
03/07/12 01:02 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Scott
I don't know what your talking about. Your last sentence about not changing a ribbon net every 2 yrs contradicts what the rules says. I've read it 3 times. If you run between 7.50 and 9.99 with a ribbon net you have to change it every 2 yrs.
Re: Window net rules changed again as of 03/05/12 [Re: Keith Richards] #1192212
03/07/12 01:06 AM
03/07/12 01:06 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
It's always fun teching a 10 sec car that has a full cage.... and we went with the window net because there was always some tech moron that said it was required with a cage.
Re: Window net rules changed again as of 03/05/12 [Re: OUTLAWSSAA] #1192213
03/07/12 01:54 AM
03/07/12 01:54 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Scott
No it says if you run between 7.50 and 9.99 you have to run a Ribbon net or a SFI 27.1 mesh net. then it goes on to say all the SFI nets have to be re-certed every 2 years. It does not say the ribbon ones for 7.50 to 9.99 have to
Re: Window net rules changed again as of 03/05/12 [Re: J_BODY] #1192214
03/07/12 01:55 AM
03/07/12 01:55 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
In english, decifered for you who continue to struggle:
MESH type nets have always been replaced every 2 years.
RIBBON type were allowed to be used longer, then the rulebook changed it to every 2 years, then NHRA got major backlash, now they have relented, and returned to allowing RIBBON type nets to continue in use.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Window net rules changed again as of 03/05/12 [Re: SB412DUSTER] #1192215
03/07/12 02:06 AM
03/07/12 02:06 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Scott
You need to look a little closer.
Re: Window net rules changed again as of 03/05/12 [Re: OUTLAWSSAA] #1192216
03/07/12 02:18 AM
03/07/12 02:18 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Read the whole thing again a little slower and you will see it
Re: Window net rules changed again as of 03/05/12 [Re: SB412DUSTER] #1192217
03/07/12 02:43 AM
03/07/12 02:43 AM
Sorta like reading stereo instructions. But yes, the simple answer is the common ribbon nets only need to have a current SFI cert if you go faster than 7.50. ALL Mesh nets must be SFI cert.
All cars running nets that are required to be certified must have them re-certified or replaced every 2 years.
Re: Window net rules changed again as of 03/05/12 [Re: ProStDodge] #1192218
03/07/12 03:16 AM
03/07/12 03:16 AM
Arizona
Chris'sBarracuda Offline
Arizona
Scott
The key wording there is "ribbon type OR SFI 27.1 Mesh Type"
Doesn't say SFI Ribbon Type..
But, like Al.. Have already spent the money.. Thanks again NHRA..
Chris..
