Window net rules changed again as of 03/05/12
#1192199
03/06/12 12:29 PM
03/06/12 12:29 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
NHRA has changed its thoughts on the window net rule for cars slower than 7.49 (4.50). The section in RED has been REMOVED and replaced by the section in BLUE. SECTION 20: GENERAL REGULATIONS, INTERIOR: 6, WINDOW NET (Page 29) (3/5/2012) An SFI 27.1 ribbon-type or mesh-type window net is mandatory on any full-bodied car required by the rules to have a roll cage. An SFI 27.1 ribbon-type or mesh-type window net is mandatory on any full-bodied car running 7.49 (*4.49) or quicker. For full-bodied cars running 7.50 (*4.50) to 9.99 (*6.39) or if vehicle runs 135 mph or faster a ribbon-type or SFI 27.1 mesh-type window net is mandatory unless otherwise specified by class requirements. SFI 27.1 window net, when required, must be updated at two-year intervals from the date of manufacture. Window net must be securely mounted on the inside of the roll cage, with the permanent attachment at the bottom. All attachment points must be designed in an attempt to protect the driver and avoid contact with track surface or guardwall. Eyelet clips, dogleash hardware, hose clamps, etc. prohibited. Penetration of webbing, except as performed by manufacturer, prohibited. Any modification to net must be performed by manufacturer. NHRA members can find this information in the "Rulebook amendments" section on the www.nhraracer.com site. This change means the SFI ribbon style nets are not needed until you run faster than 7.49. So you don't need to be changing your ribbon net every 2 years, unless you have a mesh style net, or run faster than 7.49 (4.50) Scott
Re: Window net rules changed again as of 03/05/12
[Re: Al_Alguire]
#1192201
03/06/12 12:38 PM
03/06/12 12:38 PM
Posts: 5,875 communist bloc of new jersey
jamesc
As usual someone is on the ball with changes. Some of us have already run two divisional races and purchased new stuff. Oh well it looks so much better than the perfectly good one it replaced
do i detect a hint of sarcasm there Al?
[Re: ProStDodge]
#1192203
03/06/12 12:56 PM
03/06/12 12:56 PM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
??????????? 7.50-9.99 window net mandatory, sfi 27.1 still says updated every 2 years, am i missing something, only had 1 coffee so far
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#1192204
03/06/12 12:59 PM
03/06/12 12:59 PM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
It says a ribbon type or an SFI mesh type
[Re: tboomer]
#1192206
03/06/12 01:25 PM
03/06/12 01:25 PM
Posts: 16,929 NC
440Jim
NC
I hope I can still cancell my back order for a new window net. My current ribbon type is only 2 years old.
I hate spending money on something of no benefit and no longer required.
EDIT: Summit was able to cancel my backorder. This was ordered on 2/7, first delay to 3/3, then to 3/11. Evidently a lot of people were ordering these, many more than more years. Likely due to the NHRA rule mess.
[Re: 440Jim]
#1192208
03/06/12 01:41 PM
03/06/12 01:41 PM
Posts: 20,657 in a cattle trailer down by th...
Guitar Jones
Well I guess not having money has it's privileges.
[Re: ProStDodge]
#1192211
03/07/12 01:02 AM
03/07/12 01:02 AM
Posts: 993 Addison,IL
OUTLAWSSAA
Addison,IL
Scott
I don't know what your talking about. Your last sentence about not changing a ribbon net every 2 yrs contradicts what the rules says. I've read it 3 times. If you run between 7.50 and 9.99 with a ribbon net you have to change it every 2 yrs.
[Re: OUTLAWSSAA]
#1192213
03/07/12 01:54 AM
03/07/12 01:54 AM
SB412DUSTER
Mobile Alabama
Scott
No it says if you run between 7.50 and 9.99 you have to run a Ribbon net or a SFI 27.1 mesh net. then it goes on to say all the SFI nets have to be re-certed every 2 years. It does not say the ribbon ones for 7.50 to 9.99 have to
[Re: J_BODY]
#1192214
03/07/12 01:55 AM
03/07/12 01:55 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
In english, decifered for you who continue to struggle: MESH type nets have always been replaced every 2 years. RIBBON type were allowed to be used longer, then the rulebook changed it to every 2 years, then NHRA got major backlash, now they have relented, and returned to allowing RIBBON type nets to continue in use.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: SB412DUSTER]
#1192215
03/07/12 02:06 AM
03/07/12 02:06 AM
OUTLAWSSAA
Addison,IL
Scott
You need to look a little closer.
[Re: ProStDodge]
#1192218
03/07/12 03:16 AM
03/07/12 03:16 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Scott
The key wording there is "ribbon type OR SFI 27.1 Mesh Type"
Doesn't say SFI Ribbon Type..
But, like Al.. Have already spent the money.. Thanks again NHRA..
Chris..
