69 B-body stretching tubs and tire sizes? #1190681
03/03/12 11:21 PM
03/03/12 11:21 PM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Looking for a Nostalgia look, need pictures of tub work and tire sizes by moving springs in 3-inches and splitting inner tub to widen. Anyone have good pictures or experience? I want to run DOT M/T or Quicktime Pro on wheels...
Thanks,
Ed
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190682
03/04/12 10:18 PM
03/04/12 10:18 PM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Nobody?
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190683
03/04/12 10:53 PM
03/04/12 10:53 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
here is a link to the road runner forum. you may not be able to view it unless you sign up. some good pics of a member relocating the springs and a mini tub.
http://69roadrunner.net/phpBB3/viewtopic.php?f=6&t=3031&hilit=mini+tubs
Re: 69 B-body stretching tubs and tire sizes? [Re: macmic87] #1190684
03/04/12 11:52 PM
03/04/12 11:52 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
I'm so proud of you for going against the grain. By the way, cragar has a 61015-spec. It's a special order backspace 10" S/S wheel. No need to cut the axle that way. Check it out on summit's website.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: 69 B-body stretching tubs and tire sizes? [Re: gtsuperbee] #1190685
03/05/12 08:59 PM
03/05/12 08:59 PM
There's a few guys on here that have mini tubbed B-bodies just give them time to see the thread.
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190686
03/05/12 10:26 PM
03/05/12 10:26 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Ed, the best article I've ever seen on factory wheel tub widening was in Mopar Action? when they did the Project Six Pack A12 Road Runner in the late '90's? Stock wheel tubs were widened 3", good explanations and photos along the way. Maybe someone can dig up the issue and post it.
Re: 69 B-body stretching tubs and tire sizes? [Re: Dave Watt] #1190687
03/06/12 12:29 AM
03/06/12 12:29 AM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Thanks for any info and encouragement!
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190688
03/06/12 08:30 PM
03/06/12 08:30 PM
west palm beach, florida
modelmakerinc Offline
well its not a 69 but it is a b-body and they are all about the same. here is my 67 Coronet, it is very basic, you cut away the sheetmetal from between the factory tub and the frame rail then you cut a longitudinal line in the squarest part of the tub. weld it to the frame rail and then use a filler strip in the gap, remember it will affect your back seat, unless you do it to a C-Body
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 69 B-body stretching tubs and tire sizes? [Re: modelmakerinc] #1190689
03/06/12 08:31 PM
03/06/12 08:31 PM
front side
Re: 69 B-body stretching tubs and tire sizes? [Re: modelmakerinc] #1190690
03/06/12 10:51 PM
03/06/12 10:51 PM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Thanks, so did you go tight to the side of the rail and trim off the flange on the top of the rail? Any bottom shots?
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190691
03/07/12 12:18 AM
03/07/12 12:18 AM
actually I left a small 3/16" of the framerail flange where it turns horizontal. I used it as a great place to weld the trimmed wheel tub since it is .080 thick and easy to run a bead on, it helps that the stock wheel tub metal is a good gauge thickness as well, the aftermarket wheeltub material are like 24 or 26 guage.
no underneath shots sorry
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190692
03/07/12 12:33 AM
03/07/12 12:33 AM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
That is what I did, but I also boxed the inside of the frame rails. I have 335's on the back and there is a good 2" of additional space for going wider. Look at mnitubs link on my web site v10mopar.com
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190693
03/07/12 10:23 AM
03/07/12 10:23 AM
Jacksonville Florida
elitecustombody Offline
Leave as much of stock inner wheelhouse (about 3-4 inches),remove the rest and weld in brand new AMD wheelhouse.That way it's way less work and the job is much cleaner with new tubs
Re: 69 B-body stretching tubs and tire sizes? [Re: elitecustombody] #1190694
03/07/12 11:04 AM
03/07/12 11:04 AM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
Good idea there.
Ed, you've seen photos of mine already. You have to modify the trunk hinge bracket and the sheet metal in front of v-bracing to fit the new inner tub shape.
Everybody makes fun of a hillbilly until they need something fixed
Re: 69 B-body stretching tubs and tire sizes? [Re: B_Body_Bob] #1190695
03/07/12 12:31 PM
03/07/12 12:31 PM
Tehachapi CA
MRBELV2 Offline
MRBELV2  Offline
Tehachapi CA
I did the 3" spring relocation kit and mini-tub on my 66 belvedere. I had to modify the rear seat frame, but the front of the seat is unchanged. I cut to the framerail, so the tub is against the frame-no flange left. Really not that hard to do. Go for it. It will look awesome!
Re: 69 B-body stretching tubs and tire sizes? [Re: MRBELV2] #1190696
03/09/12 12:12 AM
03/09/12 12:12 AM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Thanks All, I like the idea of splicing in the new inner instead of the strip. But my fab guy has been doing this for years so he may say don't bother? Like to look at ALL possible methods........
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190697
03/12/12 10:25 PM
03/12/12 10:25 PM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Anyone else?
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190698
03/13/12 08:59 AM
03/13/12 08:59 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I'm in the middle of mini-tubbing my '69 Roadrunner. I've never done one before so its a learn as I go process. It looks and sounds like a simple job, but you do have to use your brain a little and that hurts. I have pics of my car in the Projects section, but I haven't posted any of the mini-tubs yet. I will post them when after I finish the tubs. Also I did use my original inner fenders, but if I had thought of buying new ones I would have looked into possibly going that route. Oh well. Anyway my tubs are installed, I just need to finish welding and blending in the extra strip of sheetmetal so it won't look to obvious.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: 69 B-body stretching tubs and tire sizes? [Re: Q5_Ed] #1190699
03/13/12 09:21 AM
03/13/12 09:21 AM
Connecticut
5126brl No more Offline
Connecticut
Thanks,
Ed
Since you want what I have and I want stock lets trade!!!
Running 29.5x15.5 M/T Sportsman pro's.
Tubbed all the way to rail. Factory A-12
Re: 69 B-body stretching tubs and tire sizes? [Re: 5126brl No more] #1190700
03/14/12 11:18 PM
03/14/12 11:18 PM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
It's not quite that simple.... just want to put my own spin on it.........Thanks for the offer though, my buddy is doing a clone of an original Y2 car.
