paint guys, shade tree repair
#1190553
03/03/12 10:39 PM
03/03/12 10:39 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Picked up a straight fender today to replace the "customized" one on my Ram. New fender is dark green metallic, where my Ram is dark metallic burgundy. Am I safe just wet sanding the green donor and spraying burgundy, or do I need to use a primer first (red, gray, black) for a good color match???
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
Re: paint guys, shade tree repair
[Re: BulletBob]
#1190555
03/03/12 11:22 PM
03/03/12 11:22 PM
GO_Fish
Maryland
Are you saying strip it to bare metal first?? I guess you lost me on "seal it".
Scott B.
[Re: BulletBob]
#1190556
03/03/12 11:27 PM
03/03/12 11:27 PM
Posts: 394 md
wicked
md
Sand it ,seal it & paint it.
X2 if the old surface is intact with no peeling etc
[Re: wicked]
#1190557
03/03/12 11:35 PM
03/03/12 11:35 PM
GO_Fish
Maryland
The clear coat on the top side of the donor fender is "spider webbing", but not lifting. I'd plan on wet sanding off the deteriorated clear coat before I spray.
Scott B.
[Re: GO_Fish]
#1190558
03/03/12 11:40 PM
03/03/12 11:40 PM
Posts: 394 md
wicked
md
all that bad clear needs to come off even if it looks like it sands ok, the spider webbing would show back up and I would prime and block it doing it that way. Sometimes those little spider webs are down to the base /primer, however deep it has to get sanded off to avoid issues later.
[Re: GO_Fish]
#1190559
03/03/12 11:54 PM
03/03/12 11:54 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Take it down to the paint, seal it, spray it. Just my
[Re: GO_Fish]
#1190560
03/04/12 12:31 PM
03/04/12 12:31 PM
Posts: 8,500 Candler,NC / Myrtle Beach, SC
JDMopar
He meant you need to spray a coat of sealer on the fender before you paint it. Sealing is the last step before painting. Just sand all the old clear coat off, then spray the sealer and let it flash the proper amount of time per the spec sheet with the sealer...then paint it. No need to sand the sealer first. I would sand a place off on the old fender to see what color sealer was under the original paint, and buy that color sealer.
[Re: moparbroz]
#1190564
03/04/12 07:39 PM
03/04/12 07:39 PM
JDMopar
Is seal it the same as prime it? If not what kind of sealer? (Brand and series name).
Yes and no. The sealer I have used in the past is actually epoxy primer (PPG DP90LF) After you have done all your body work,priming, and block sanding...you need to spray a coat of sealer on last thing before you apply the topcoat. Like someone above said, it's probably not necessary for a backyard job. Sometimes I forget to take my mind out of " Do it by the book restoration mode."
